How To Fit A Dummy Filler Neck.
Posted 01 June 2010 - 06:03 PM
I want to fit a dummy filer neck to my Minus so it has the 'twin' tank looks.
Is there any trick people know of as to how to drill the hole in the correct position? i.e. do you take measurements or just guess?
Russ
Posted 01 June 2010 - 08:36 PM
Posted 01 June 2010 - 08:52 PM
Posted 01 June 2010 - 08:56 PM
i always thought they were a stick on thing. if you were to drill a hold for it, in the right place aswell, then why not put a tank in there
The extra cost of the tank & fittings?? The loss of boot space with an extra tank?? The fact that you don't actually want or need an extra tank??
Posted 01 June 2010 - 09:14 PM
RH tanks are very expensive plus it will be a track/fun car so is likely to have a small ally tank put in. I just want the filler neck/cap to give it that kind of retro rally look.
Has anyone fitted one?
Posted 01 June 2010 - 09:16 PM
I measured mine carefully before drilling the holes.
May not be to everyone's taste but each to their own.
Let me know if you need some measurements
Regards
Steve
Posted 01 June 2010 - 09:39 PM
Posted 01 June 2010 - 09:46 PM
I bought mine from here
http://cgi.ebay.co.u...=item20b131a979
Spot on service
Regards
Steve
Posted 01 June 2010 - 09:49 PM
Posted 01 June 2010 - 09:52 PM
what about this novel idea, since i cant stand stuff being stuck on a car that has no purpose. plumb the dummy filler into the left hand tank, would be a bit of work to get it right but at least itll be functional, plus you can use any side when filling up at the petrol station.
ive found that the mini is so small it doesnt matter which pump you go to
Posted 01 June 2010 - 11:13 PM
cheers for that. And what a lovely motor you have there, great paint work
Posted 02 June 2010 - 06:01 AM
Posted 02 June 2010 - 08:59 AM
I might try that, although Minus doesn't have any seams so may be a tad tricky. I could take a reference from the boot aperture though.
The tank I may use might be a Metro unit if it fits, so the boot will need opening to fill up anyway, in effect both necks will be dummies.
I realise not everyone likes this but I do not want the original petrol tank in there as its a pig to remove the damper. As the car is intended for fun/performance i'm not too fussed about this as its likely i'll need to remove the dampers etc sooner or later.
R
Posted 02 June 2010 - 09:01 AM
Posted 02 June 2010 - 12:03 PM
