Argh!
Posted 11 June 2010 - 05:26 PM
Ever since L2B the cooling on my car has somehow become worse. Even in mild conditions if overheats.
Last week, it got pretty bad, the temp gauge would always stay above the norm and creep up if faced with a hill or fast stretch. So after fitting the new oil filter, getting some expensive good quality oil, and fitting a new thermostat, i took it out for a spin, and the cooling is just as bad
It's driving me mad. This car consumes most of my income and everything i do on it ends up making it worse. There's no water leak anywhere in the engine bay, i checked. Oil levels are fine. I thought the upgraded radiator, new hoses and new thermostat would improve cooling a lot, but it hasn't changed a bit.
What could be wrong? I have to know because i'm falling out of love with my car
Posted 11 June 2010 - 05:34 PM
My first thoughts are that your water pump is no good, it's not unknown for the pressed impellor to rust and become ineffective. Only way to check is by taking it off.
Ohter things could be a lean mixture or incorrect timing or a head gasket failure.
Posted 11 June 2010 - 05:46 PM
Posted 11 June 2010 - 05:56 PM
Timing and mixture are spot on, the car was RR'd a weeks before L2B. The water pump may be the answer, if hasn't been replaced in a while and it didn't enjoy the freezing winter very much. They're not very expensive to buy so i'll order one and see if that does the trick. If it doesn't i'll snoop about and see if any oil is leaking from under the block head. Thanks It just drives me mad when i've spent a lot of money on something and it doesn't do anything!
i had this problem
it might be silly but when the water pump was changed are you sure the mechanical fan is the right way around?
i had that problem doh
Posted 11 June 2010 - 06:54 PM
Posted 11 June 2010 - 09:06 PM
Posted 11 June 2010 - 10:14 PM
Cheers,
Andrew
Posted 12 June 2010 - 10:47 AM
Which way round should the fan go? My dad was the last person to fiddle with the radiator/fan so i can't remember which way it went. There's a smooth side, and a side in which the centre has lots of little indents.
At the moment, the smoother side is facing the radiator and the indented side facing the block. Is that the right way around?
Posted 12 June 2010 - 12:41 PM
Posted 12 June 2010 - 12:57 PM
Thats your problem i think, turn the fan round and all should be good
So my fan is the wrong way around???
Posted 12 June 2010 - 01:02 PM
engine --------- ( --------- Radiator
Roy, can you elaborate a bit on running drain cleaner in the block? What does that do to the radiator?
Posted 12 June 2010 - 01:06 PM
This is my fan. Should the side shown in the photo be facing the block or the radiator?
Posted 12 June 2010 - 01:09 PM
edit : sorry i was a bit slow typing that out
Edited by E-Tizzle, 12 June 2010 - 01:17 PM.
Posted 12 June 2010 - 01:18 PM
yeah i was right. im uploading a picture for you.
when looking from front of car. engine .... \ .... radiator
Edited by E-Tizzle, 12 June 2010 - 01:39 PM.
Posted 12 June 2010 - 01:59 PM
