Tips To Stop Your Mini Being Nicked
80 replies to this topic
#46 scotty_18
scotty_18
  • 884 posts
  • Local Club: LMSOC
Posted 26 July 2010 - 11:55 AM
Think im going to instal a push start to my mini, but put the button in a random place so nobody will be able to find it :D
#47 jake cooper
jake cooper
  • 159 posts
Posted 26 July 2010 - 01:12 PM
I'm fitting a battery isolator in the boot - ( about 25 quid from Deamon Tweeks) The boot is quite hard to break into (compared with the rest of the car).
I'm fitting a switch on the signal wire to the starter and hiding it behind the dashboard as suggested earlier in the thread.
Also I'm fitting a dummy alarm flashing LED (approx 60p from Maplin) to the dashboard. I'm wiring the live to a permanent live and the earth to an ignition live, that way when the ignition is on the light doesn't flash, but when it is off it flashes.
It is pointless fitting a good alarm as it will be really easy to bypass as the wiring on the car is so simple.
Obviously it will still be possible to steal the car and nothing can stop a thief with a truck ... but hopefully it will deter the petty TWOCer.
IMHO !
I would change all of that, as you have just told all the internet what you security system is for your mini.
It's a sad world we live in and mini's are more likely to be nicked by people into them.
Seriously please don't tell people what/how you secure your mini.
A cut off switch / a good alarm / Steering wheel/ gear stick hand brake lock type thing. I would say is the way to go.
#48 suziwong
suziwong
  • 57 posts
Posted 26 July 2010 - 07:54 PM
Length of chain around the front wishbone and a sturdy structral house post is my anti theft device
Good luck hot wiring it though as the starter and battery are both missing lol
#49 thedaz101
thedaz101
  • 65 posts
Posted 26 July 2010 - 08:21 PM
add one of these
#50 miniallsort
miniallsort
  • 4,723 posts
Posted 26 July 2010 - 09:59 PM
one of these, then you can solve all your road rage car theft and ASBO kids issues
hahahaha love it !!! :D :D :P
#51 millermilla
millermilla
  • 452 posts
  • Local Club: BMC Brighton Mini Club
Posted 27 July 2010 - 08:22 AM
I so want a trunk monkey :wub:
#52 grahamransom
grahamransom
  • 73 posts
Posted 27 July 2010 - 03:49 PM
so i guess my anti theft dog isnt as effective as your rotties :wub:
#53 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
  • Local Club: www.lcmoc.com
Posted 27 July 2010 - 07:07 PM
When I had a Mini I wired one side of the coil to earth via a switch hidden under the dash. I can't remember which side of the coil though, but when the switch was closed i.e. one side of the coil connected to earth, the car would just turn over and not start. This would only put off the opportunist though.
Another one is a battery cut off switch. There's one called DIS-CAR-NECT which is about £12 from Minispares which breaks your battery earth strap with a screw-out knob so you can simply unscrew it and take it with you when you leave. Again, this would only put off an opportunist.
Alongside all the above you could try wire up a camera and have it on say 24 hour record where it records the last 24 hours and keeps taping over the last day. At least then if it does grow legs and walk off one day you might have an idea who took it. I wish I'd done that now.
#54 samsfern
samsfern
  • 5,243 posts
Posted 27 July 2010 - 07:37 PM
heres mine, battery cut-off switch, fuel and ignition switches, tracker, and its chained up everynight, both front wheels to steel fences, and a chain through both back wheels to a hoop in the ground, and a security light on the wall, yes, youve probably guessed it, i do live in a shitty area, where yobs are likely to nick it, although they probably wont be able to start it, as the other security feature is a choke, lol
it is a bit of a bugger if im in a hurry, but at least itll always be there, or if it is taken i can track it and get it back, lol
#55 Carlzilla
Carlzilla
  • 1,907 posts
  • Local Club: Splinters Mini Club
Posted 27 July 2010 - 07:42 PM
thats pretty secure, but nothin against some bolt croppers im afraid. would put a hell of a lot of people off though :gimme:
#56 samsfern
samsfern
  • 5,243 posts
Posted 27 July 2010 - 07:44 PM
i also leave it in gear and take the gearstick indoors, lol
#57 Carlzilla
Carlzilla
  • 1,907 posts
Posted 27 July 2010 - 07:46 PM
LOL :gimme:
#58 coopdog
coopdog
  • 4,506 posts
Posted 27 July 2010 - 07:49 PM
LOL
how do you do that?
#59 samsfern
samsfern
  • 5,243 posts
Posted 27 July 2010 - 07:51 PM
what take the gear stick out? my gator isnt screwed down, so i just slide it up the gear stick (ooer..) and twist the thing that holds the gearstick on the linkage thing, lift it out, hey presto!
its funny when i get in it, put the harness on, go to start it, realise theres no gearstick, have to go back indoors, get asked "what have you forgotten" i reply, my cars nob, lmao!
Edited by samsernie, 27 July 2010 - 07:52 PM.
#60 coopdog
coopdog
  • 4,506 posts
Posted 27 July 2010 - 07:52 PM
haha
i think that would stop some one :L
