High Oil Pressure On New Engine
Posted 07 July 2010 - 07:15 PM
I've had the engine idling on my newly installed megajolt ignition, which isn't wired to the rev counter so I can't tell you any RPM figures. I'm guessing its been idling between 1000rpm and 2000rpm, i've been using my hands on the choke/throttle as they're not connected either.
My oil pressure gauge is reading off the scale. The gauge goes up to 100 and the gauge whips straight round to that as soon as the engine is cranked over a few times and stays there when idling. I've only had the engine running for around 30 seconds, because once i'd seen the gauge I turned it off in case I was going to damage something, so these readings are from stone cold.
Any ideas? I've done a search and read about the adjustable oil pressure valves and cutting down springs but wanted some opinions on causes of this first.
Posted 07 July 2010 - 07:19 PM
Maybe try a standard oil pressure relief valve, thats what id do first, never have liked the idea of a ball bearing....
Edited by samsernie, 07 July 2010 - 07:20 PM.
Posted 07 July 2010 - 07:20 PM
Try that first.
Posted 07 July 2010 - 07:36 PM
Posted 07 July 2010 - 07:41 PM
Until i run out of oil that is .
Posted 07 July 2010 - 07:46 PM
Reduce the length of the spring on the ball bearing. The BB relief valve is good - but you do need to adjust the spring - aim for no more than 80 psi oil pressure. I'm assuming the gauge was good before - and nothing has been changed ?
As above.
I needed to cut at least a full coil off the end of my spring, to get it down to 70psi, with the ball and spring kit.
But planning to change back to the standard alloy cup and spring as a few people have concers about the ball and spring combo in a road car.
Posted 07 July 2010 - 08:06 PM
So how much should I cut off to start with?
So if im aiming for 80psi - Is that from cold at idle?
Edited by mike., 07 July 2010 - 08:09 PM.
Posted 07 July 2010 - 08:09 PM
Posted 07 July 2010 - 08:33 PM
I found the ball bearings gave inconsistant oil pressure through the rev range. But as above you need a shorter spring if you want to use the ball, I think minispares sell a shorter spring.
Posted 07 July 2010 - 09:54 PM
What sort of oil pressure should I be aiming for? Other members on here and in past threads have said aim for about 80psi, 60psi and then theres articals out there from the likes of keith calver saying aim for 25psi at idle and 60 whilst driving. What is a safe level of oil pressure to run at idle and what should that increase to when the revs rise?
Another quick question; once i've got my engine running with nice oil pressure, what do I need to know about bedding the new cam in. From what i've heard its simply running the engine at fast idle for 20 minutes - Is this right?
Posted 07 July 2010 - 10:19 PM
25 psi will be fine for idle, and 50- 60 psi when driving are what i normally go for on a road engine....
Edited by samsernie, 07 July 2010 - 10:20 PM.
Posted 07 July 2010 - 10:35 PM
Why do peoples opinions on oil pressure vary so much? I'd of thought it's a pretty crucial thing to get right, but from what it seems as long as its not ultra low or ultra high its fine.
Posted 07 July 2010 - 10:58 PM
you wont damage the motor by running 70 to 80psi hot while driving,50 idleling but its not necessary.
you mention what Keith Calver says regarding oil pressure,samsernie runs this on his and i run a bit higher than this,around 40 hot idle,and 60 driving,with no detrimental effect.
You need constant pressure not high pressure.
I would take note of what Calver says,as he does explain why this is, not just recommends a figure,and reading through it makes sense.
I personally have not had any trouble with the ball type relief valve,i also use an adjustable type from minispares.
You can through trial and error cut the spring,but its easier and quicker with an adjustable type,and you can do it with engine running and someone watching the gauge.
hth
dave
Posted 07 July 2010 - 11:14 PM
Posted 07 July 2010 - 11:24 PM
im not a big fan of the ball bearing thing, personally id chuck it in the bin and fit a standard one.
customcart on here told me a way of making the oil pressure adustable, might be worth pm'ing him...
Edited by samsernie, 07 July 2010 - 11:31 PM.
