Gearbox Inspection And Help
28 replies to this topic
#16 n00b
n00b
  • 177 posts
  • Local Club: -
Posted 13 July 2010 - 12:12 AM
yes indeed i have the 3.44 - 1 ratio which would explain why it was screaming its nnnnnnufs off at 70mph. I am hoping to replace the ratio drive for a wider one but im unsure of how far to go with it being a small bore thou. . im hoping the stage 3 will do a little more 1hp here and there. While im there im thinking of new springs and balls :) and some bualk rings for 1st and 2nd. Would you recommend new syncros too while its apart.
#17 n00b
n00b
  • 177 posts
  • Local Club: -
Posted 13 July 2010 - 12:19 AM
ive just read up on the a series gearbox the syncros and baulk rings are pretty much quite simmilar in being the exact same thing!?
#18 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 13 July 2010 - 06:40 AM
Baulk rings are about £6 or £7 so i would replace all four while your in there. And you should allways replace the mainshaft double roller bearing. 3.44 drive is probably the best compromise for a 998 engine. if you increase the ratio to 3.1 then you will get a better high speed cruise, less revs at 70, but will loose out on acceleration. A standard 998 will really struggle beyond a 3.1 and would be dead if you fit a wide ratio gear set. Its all about torque really.
#19 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 13 July 2010 - 07:20 AM
one of the questions originaly asked was how to remove that nose bearing.As said,remove all the rollers and then the cage and at that point the socket will go on,removing the nut brings the inner part of the bearing off with it.
#20 n00b
n00b
  • 177 posts
  • Local Club: -
Posted 13 July 2010 - 01:01 PM
In that case the final drive ratio will remain untill i happen to get my mits on a 1300. i did see minispares own BRings and for the cost of them i might aswell replace them too.
thank you for your help, i have so far removed the rolllers and attempting to undo the nut but blimey. . its well and truely on there. Also Andyminimad did say the box will want to follow which is my main problem as i dont have a vice or what have you so Im considering using a mates windy gun to get the bladger off.
#21 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 13 July 2010 - 01:43 PM
Be carefull if useing a windy gun, the shocks which undo the nut will travel up the shaft and into the gears which are holding the box ridgid. Could be bad news, £££££££, if a tooth snaps. i found the best way to hold the box was to jack the car up and GENTLY lower the weight onto the upturned box. Or if you know some one at a garage get the ramp lowered onto it, again only enough to hold it steady while you get the nuts off.
#22 n00b
n00b
  • 177 posts
  • Local Club: -
Posted 13 July 2010 - 02:09 PM
Thanks again for your help, i must be dragging this on although its my first rebuild.
im taking the box to a mini friendly garage and the guy said hell have a look. He specialises in rebuilds and gearboxs and supplies them for the local mini rally team :thumbsup:
#23 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 13 July 2010 - 03:12 PM
Why not start a project thread so we can watch your progress. I love a good laugh. only joking. Really its great to see how other people do stuff, and its how we all learn new ways of dealing with the problems.
#24 n00b
n00b
  • 177 posts
  • Local Club: -
Posted 13 July 2010 - 10:30 PM
i may well have to, although it will most probably turn into a quiz with the amount of questions im asking.
Speaking of Q's haha i found this as it dropped out of the bottom when undoing the 150 f tighties when i turned the box over.
looks to be some sort of retaining ring? look familiar?
#25 n00b
n00b
  • 177 posts
  • Local Club: -
Posted 13 July 2010 - 11:00 PM
Iv had the box completley dissembled part for part, i cant see where it would have come from? *baffled*
#26 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 13 July 2010 - 11:41 PM
wow! i'll have a think about what that is my guess right now is the half moon seal.
#27 n00b
n00b
  • 177 posts
  • Local Club: -
Posted 14 July 2010 - 12:21 AM
it does look like it, although i thought they where made from a rubber/plastic compound?
#28 GraemeC
GraemeC
  • 7,440 posts
Posted 14 July 2010 - 07:04 AM
Looks like a cam bearing to me!
#29 liirge
liirge
  • 4,097 posts
Posted 14 July 2010 - 10:28 AM
Is it not rubber? hard to tell from the picture, dont know if the 'HARD' half moon seals are rubber and metal backed?
but now you mention it a Cam bearing does fit the profile!
the other thing i can think of is a bush of some sort, maybe output shaft...its a bit of an enigma!
