Has Anyone Fitted Front Speaker Pods?
#16
Posted 15 July 2010 - 09:22 PM
#17
Posted 15 July 2010 - 09:34 PM
#18
Posted 15 July 2010 - 09:36 PM
i didn't want speaker pods below the dash or speakers in the doors so i made some cans and sunk the speakers into the inner wings although only any good if your repairing the inner wings or fancy going mad with a welder
nice work!
#19
Posted 15 July 2010 - 10:02 PM
Heres mine from Optimise 5" pods which i think look way better than those sqaure ones!!
Are they the dash mounted ones?
T.
Yeah called under dash mounted ones.
#20
Posted 15 July 2010 - 10:07 PM
'Bunch' for these do you have to screw into the arches to fit them?
They meant to bolt to existing holes in lower dash rail and rear of pod just rests on wheel arch, I had difficulty in getting bolts in so in end used zip ties works a treat so not solidly mounted either but back is covered by carpeted wheel arch even with my 5" get some decent enough base for me!
As they black carpet to match most peeps think thats where speakers are put normally from factory!
#21
Posted 15 July 2010 - 10:27 PM
T.
Thought they were.
Did they get in the way of you bonnet pull?
#22
Posted 15 July 2010 - 11:56 PM
The only problem with speakers in door pockets is that to fit them properly you have to drill holes in the door pillar and door for the wires to pass through.
With the ones in the link you dont.
mine door speaker pods that were fitted to mine where just wired through where the door checkstrap thingybob and into the door, no holes required
#23
Posted 16 July 2010 - 07:44 AM
T.
Thought they were.
No mine is just above see picture, mines a 93' Sprite so not sure if its position has ever changed or anything.
