Making A Classic Mini Safe
#16
Posted 16 August 2010 - 11:07 PM
Link:
http://www.britishpa...rd.php?id=72595
#17
Posted 16 August 2010 - 11:13 PM
and issigonis was criticised but said that the minis superior handling and brakes meant that it was less likely to crash ...allegedly
I think that was in this TV clip below on the early Mini taken from a 1999 CH4 Documentary on Car Safety. It also shows why the door latch/locks were changed for safety reasons on the Mk3 onwards, the large cut-outs put into the metal parcel shelf and the front seat catches added......
TEbmPsukEHI
#18
Posted 17 August 2010 - 09:15 PM
In Australia my classic low seats are called back breakers for a good reason. A good hit from the back and........ I shudder to think. That's why I will be going with full seats with neck support, even though I need engineering approval.
#19
Posted 21 August 2010 - 08:07 PM
#20
Posted 21 August 2010 - 08:21 PM
minis arent safe & never will be, no matter how many rollcages, door bars, bucket seats etc people put in
Hmmm, I think my full roll centre MSA approved cage made of complete CDS, magnum fibreglass FIA approved buck seats mounted to the roll cage and securon 3" FIA approved harnesses bolted to the roll cage would prove differently...
as would mini93's setup...
Ask bill richards if his mini was safe when he had his recent crash and why... and i think he would agree with me
#21
Posted 21 August 2010 - 08:25 PM
#22
Posted 22 August 2010 - 06:55 AM
you have to do a "defensive driving course" to understand how even in those situations you can reduce the chance of it happening or reduce the damage to yourself - its all about anticipation and reading the road ahead and behind, its was a real eye opener for me and well worth doing especially when driving a mini. If you want to reduce accidents someone suggested cars shoud be made of glass or have big spikes sticking out of the steering wheel, i think that would work!Great links! Anything over 30 miles and it looks like serious thoracic damage. Being the sole bread winner with little ones to support means I am concerned about safety. Luckily, I drive a new car with a 5 star safety rating and the mini is my fun car (once I finish it). It was interesting to note the few people saying just be a better driver will make you safer. Sure, if the accident is your fault. Well, that works if you are the only driver on the road. There seems to be a sudden spate of stories about mini's being rear ended on here lately and a few about being T boned in the Aussie forums. I don't know how being a better driver will help in that situation.
Getting back to daves point tho , your mini should be maintained well as the safety aids are not up to modern day standard and brakes etc should be maintained properly, roll cages may be an idea if you really think (or drive like) you are going to die but I tend to think I'll reach journeys end safely and drive accordingly
#23
Posted 22 August 2010 - 10:17 AM
famous last words... most accident are unavoidable unless you have burnards watch.
#24
Posted 22 August 2010 - 10:43 AM
#25
Posted 22 August 2010 - 11:08 AM
Along the lines of falling out of an aeroplane isn't dangerous, it's the sudden stop when you reach the ground - Minis are smaller & lighter than most other things on the road, if you collide with something else it's you that will do most of the sudden stopping. Even if your Min is so well braced the only thing you hit is your harness straps it could still cause you nasty damage.
In a way Issigonis was right: not having the accident in the first place should be even more prescient if you're in a Mini.
#26
Posted 22 August 2010 - 05:32 PM
try a car with: No roof, No sides, a fuel tank next to the passenger seat and a windscreen that's only held on by bolts.
its called a:
Mini! (Moke though!)
#27
Posted 22 August 2010 - 06:21 PM
The problem is with a mini the engine/gearbox coming to meet you inside the car, what your sitting in or secured by won't help, you need to stop the engine coming through the bulkhead, so unless you have a very substantial rollcage supporting the front bulkhead area, a normal six point rollcage wll not help in this respect.
One of the things that always amazes me given how long the mini was in production for is, at no point did they put a collapsable column in, surely easy enough for a major manufacturer to implement. When you have a hard impact on the front end of a mini the steering column it fires upwards into the chest/face area, killing you or badly injuring you.
David
#28
Posted 22 August 2010 - 07:28 PM
#29
Posted 23 August 2010 - 05:09 AM
eh? - i think you mean most accidents are avoidable - unless you drive like a dick of course!,
#30
Posted 23 August 2010 - 08:53 AM
