Right a big problem, slacking the head off to stop it warping and placing the rockers back on to try and stop the head lifting whilst cranking it over testing for oil did not work and water went all into the pistons everywhere past the gasket. Stripped it down in 20 mins and ordered some new gaskets. I still can't see much oil coming through but the hole. I will check tomorrow and see if it comes through block.
Sorry this is being so difficult. Out of curiosity... when you went through the steps you described above, you DID remove the spark plugs didn't you? If you forgot to remove the plugs when you removed the rocker shaft assembly the compression will have been what lifted the head off the block and caused your coolant leakage.
