best con rods to use?
Posted 01 December 2005 - 11:22 PM
Should i use Arrow con-rods or Cooper S????
or are there any others?
what about shot peening and polishing?
Posted 01 December 2005 - 11:31 PM
Posted 02 December 2005 - 08:00 AM
Obviously though, the lighter arror the con-rods will lighten the rotating mass and so should be capable of reving freer? MiniSpeed had lightweight steel con-rods on offer for about £700 a while back?
But my suggestion in your quest for reliability is to make sure all the ancilaries are upto the power. Get an uprated starter motor. Make sure you use the right spark plugs, MiniSpares 2 core rad, silicone hose set and maybe an deep impellor water pump?
Posted 02 December 2005 - 08:02 AM
Siggy
Posted 02 December 2005 - 08:34 AM
Posted 02 December 2005 - 11:28 AM
Posted 02 December 2005 - 02:01 PM
EDIT: i notice your concidering using arrow rods, if your going this way im taking it your thinking of a high revving race engine. In my opinion these are the only rods to use, dont even think about using minispares ones. I learnt this after buying some myself for a short stroke unit im building. If i had the cash i'd sell the minispares rods and buy some arrow ones, but funds no longer allow.
Posted 02 December 2005 - 02:11 PM
Posted 02 December 2005 - 02:17 PM
1. They are massively unbalanced and require a large amount of time to balance/correct.
2. The big ends are machined in the wrong place in the forging and visually look uncentered.
3. They are HEAVEY at 750g+.
4.The little ends and the big ends are missaligned, 20 times over arrows highest tollerance.
5. supplied with useless bolts, need to buy ARP at extra expense.
Also 2 seperate engine builders have told me that some are cracked.
Posted 02 December 2005 - 02:21 PM
Are these for the tappets or somthing else...
Posted 02 December 2005 - 02:27 PM
Posted 02 December 2005 - 02:28 PM
Posted 02 December 2005 - 03:21 PM
ive got to keep up with jammy and minis84 on the track....
although this is a track car it will be used on the roads some times, which is why i want the best reliability too, i figure if i build it to the best standards, it wont let me down
as for the arrow rods, anyone know what they weigh?
Posted 02 December 2005 - 03:34 PM
Awww, ain't that cute! Although gotta say, the only way you'll keep up with me is if your in my passenger seat! :tongue:ive got to keep up with jammy and minis84 on the track....
Posted 02 December 2005 - 03:39 PM
Oh, and Madmax, I thought you were going 1310? How come you've moved up to 1380? (if i've missed a post somewhere then ignore me)
