1983 City E 998 To 1310 Cooper
#16
Posted 03 October 2010 - 07:51 AM
#17
Posted 03 October 2010 - 01:36 PM
#18
Posted 03 October 2010 - 05:13 PM
What i do want at the end of it all is a solid, rust free shell that looks good and has the reliability that all my cars must have, the car is not going to be a daily use car, but more a weekend and holiday/ show attending car. Its not that i want a show grade car and dont want to drive it, more i want the car to last, stay looking good and come out for the fun.
#19
Posted 03 October 2010 - 06:28 PM
Then i got started on the door step. I am still working on this, its welded in and ground back awaiting finnishing which ill do in the morning.
The rear valence and new close panles now fitted. I have to finnish seam welding and grind back to complete this. I had to stop welding as my little boy wanted to come out in the garage today so he stoped play.
The rear subframe in paint (only one coat as yet.
And the front sub in paint.
The front sub after two coats of paint and some of the poly bushes that will be fitted.
And one of the front wings trial fitted.
I will do some more work tomorrow. Hopefull get all the seams seald and the boot in primer. I have the other door step to do and the heal board and then ill move onto the wings. At this rate the car will be done on the next 6 weeks. And when it is, ill have to find something else to keep me ammused. (TRAILOR ;o)
The blue that has been used on the subframes will be carried to top and bottom arms, radius arms and back plates. It is also the colour that the car will be finnished in. The only difference with the body paint is that it will be coated in clearcoat loaded with a red metal flake and comelian pearl giving it a somewhat special finnish. You will all have to wait for that tho as im still playing with mix values. All will be revealed when im satissfied with the result.
Edited by jay whiting, 03 October 2010 - 06:37 PM.
#20
Posted 04 October 2010 - 04:02 PM
Sorry for the amout of shots of the floor, i thaght it may interest some of you to see from different angles.
I also got a little colour into the front bulkhead as well today. I will get the inner wings sorted tomorrow as well and complete the engine bay.
The front subframe is also well under way to being complete as well.
Thats all for today folks, ill get some picys of the next lot as i get on with it in the morning.
#21
Posted 12 October 2010 - 04:26 PM
As you can see from the picys, i have fitted polly bushes to everything, no old style bushes to be found on any of the build. All the breakpipes have been replaced with new as well. The radius ars have all been fitted with new backplates, wheel cyilinders, bearings and shoes. The car will be getting new shocks all round. As the picys show, the car is currently still stitting on the cones, once the mot is out the way and the cars is back on the road and settled down, i will be changing these for coils to bring a little more moderness to the cars suspension along with a slightly softer ride.
#22
Posted 12 October 2010 - 05:21 PM
#23
Posted 13 October 2010 - 06:13 PM
Well progress from today was that my 1275 engine went down to spam speed for the machine work to be started, it will be getting taken out 20thou to 1293, new cam bearings with a line bore, new followers and some high compression SLIPPER pistons, new mains and ends. The head has just been ported, nothing majour just some work on the valve throats. As im not looking for huge power i didnt se the need for large port work. Being as the head is Metro it is already fitted with the larger valves so that was money saved. Hopefully Spam will be ringing me in week to say its all acid bathed and machined so come and collect. This will allow me to start putting it back together and turn my now rolling shell back into a living breathing beauty.
The one thing that will need some work and thaught is giving here a name.......
#24
Posted 18 October 2010 - 05:04 PM
Me being me said lets do a +0.40 bore on the bad cyilinder and see what happens.......... At this poiint i left as i had stuff at home to do. As i left Spam said 'If you dont hear from me again today its worked and we are back in the game' As yet i have not heard from him so im hoping that when i go down there in the morning ill be looking at a block fully re-bored to 1310cc and yet another set of pistoms to match. If this is the case then ill be bringing it home and starting the build on the engine and gearbox.
So for those who are just starting out with a project mini and have never done anything like this before PLEASE PLEASE bare this in mind. Dont be to quick to blame the machinist if it all goes banana shaped. Yes sometimes the machine work can be to blame BUT on some occasions its the fault of the block. I have been getting engines machined for many years now and have seen many different things go wrong. 30% are due to bad machine work but 70% of all problems come from the subsrtate You take in to have machined.
The possative side to my block is that if in the morning it does all work out right, i have a 1310 not a 1293 as was the plan....... Whatever happens i will let you all know in tomorrow.
#25
Posted 23 October 2010 - 06:58 PM
Here are some pics of whats been going on over the last couple of days, i hope you enjoy and as always any comment is welcome.
Please excuse the midas badge, that will be coming off and the rocker cover will be getting a fresh polish, its just there to keep everything covered over night.
#26
Posted 23 October 2010 - 07:03 PM
Think you should keep the Midas badge on the Mg rocker box
#27
Posted 23 October 2010 - 07:15 PM
#28
Posted 24 October 2010 - 07:56 AM
#29
Posted 24 October 2010 - 11:22 AM
#30
Posted 24 October 2010 - 11:26 AM
Lol, i stumbled on this blue by mistake, and well if your going to do something then i guess do it. All the running gear is all pained the same colour as the car will end up. Im not sure i will be keeping the MG cover on the engine, its just one i had laying around after scraping my midas so have put it to use for the night.
You scrapped your Midas!
Good Luck with the Build!
