A Little Story
#31
Posted 24 October 2010 - 06:58 PM
hope you get another one sorted when you feell upto it
#32
Posted 24 October 2010 - 08:25 PM
I ran away from it as i knew the fire had started in the boot it was likely to have the petrol tank soon aflame. I watched my car go up in flames and i was in tears. My whole car and possessions burnt to the ground as i watched.
The fire brigade told me the nature of the fire was likely to be an electrical one, and they had suggested i may have had a small leak from my petrol tank. And my battery was exposed to it, as there was no cover over it.
Very sad to see this, glad you escaped in time. Unfortunately once they have caught fires can take hold of cars very quickly destroying all your hard work in seconds.
Please always take extra care with wiring in Mini's, there are a lot of sharp metal edges and pointed self-tapping screws near cable runs (eg. behind the grille!). Insulate connections and check and use rubber grommets through all holes in panels. Always secure and fit the cover over the battery, make sure the live terminal has a red plastic insulation cover like modern cars, jacks and metal tools can slide around in the boot touch the terminal...............sparks and an internal petrol tank perhaps leaking fumes through the breather pipe is all it takes............
Would not have helped much in this case but also recommend to always carry a fire extingusher and fit an emergency battery cut-out switch like race Mini's use.
I’ve hard of stories like this a few times, where the grommet in the boot floor disintegrates, the main battery then rubs though on the metalwork and the battery shorts outs and catches fire, unfortunately taking the car with it.
So as a precaution I’ve always replaced the grommet in the boot floor regardless of condition, with one with a larger inner diameter and run the cable through some coolant hose as well as the grommet.
#33
Posted 24 October 2010 - 08:46 PM
Good luck in finding another Mini and stick around to update us
#34
Posted 24 October 2010 - 08:48 PM
Such a good looking car as well
Great photography as well
#35
Posted 24 October 2010 - 08:53 PM
#36
Posted 24 October 2010 - 09:02 PM
#37
Posted 25 October 2010 - 11:01 AM
hope you find a replacement soon enough.
#38
That must have been heartbreaking for you to watch such a beautiful little mini get engulfed in flames
The main thing is that you got out ok though. Best of luck in the future, hope this doesnt put you off getting another mini.
#39
Posted 25 October 2010 - 11:35 AM
#40
keep your chin up mate and i hope you can get one back on the road in as good condition as this one was
#41
did y our car have twin tanks? as in one of the first pics there is a hole there for the neck of one?
#42
Posted 25 October 2010 - 12:42 PM
christ, hope your ok mate. where did this happen because i've taken my mini through all the back rounds around where you're from and they are great fun round there.
not too far away, just outside oundle on a backroad near a village called glapthorn. nice to see another user who has one nearby. i'll look out for you. thanks
#43
Posted 25 October 2010 - 12:44 PM
maybe that chap will donate that mini to you? i think that would be a great idea!
#44
Posted 25 October 2010 - 04:09 PM
#45
Posted 25 October 2010 - 05:35 PM
