A Red Mini, No Freaking Way!
729 replies to this topic
#436 leaky
leaky
  • 6,890 posts
Posted 12 June 2014 - 09:23 PM
Right proper update time!
The flasher units are in and the washer pump is wired up and all the exhaust brackets were fitted.
Then Ross came over and we started to build up the rear suspension.
On the passenger side everything went in well and rather quick. Heres Ross doing that.
10428541_10152978754164848_7982415442066
Then we tried to do the driver side and found some problems.
One of the captive nuts are missing off the subframe and the rest of the bolt holes did not seem to line up at all well with the camber brackets.
10360351_10152984184779848_1931821079843
Now I am still unsure on what to do about this. I really do not want to be taking the rear subby off if i can help it so any suggestions would be great.
One thing I did get done was get the tyres fitted to the wheels!
1526191_10152978356329848_63282200401672
I also got the rash fitted.
10458129_10152978754044848_7030560372294
and although I could not drop her down on her wheels I thought I would do a cheeky test fit anyway. I put the back box on as well to see what it looked like.
10340003_10152978753809848_3155712011584
10373805_10152978753594848_7949262126107
Also my new trick bonnet hinges came today so I'll have ago and fitting those the weekend and see what they are like.
10426552_10152983407479848_6693031376086
so thats it for the time being. I am kinda stuck and not sure where to go from here. I wanted to get the engine in this weekend but don't really want do to that before its on its wheels.
Bloody Minis!
#437 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 June 2014 - 11:28 PM
cracking progress mate.
Love the wheels but still not sure about the tailpipe.
All downhill from here now!!!
Ben
#438 leaky
leaky
  • 6,890 posts
Posted 13 June 2014 - 09:41 AM
Will be as long as I can work out a way of doing that subframe without taking the subframe off
#439 geoff-d
geoff-d
  • 468 posts
Posted 13 June 2014 - 04:54 PM
Told you how to do it. Pop over & I will show you on a spare Subby .
#440 leaky
leaky
  • 6,890 posts
Posted 15 June 2014 - 02:45 PM
Well I fitted these trick hinges today.
1623219_10152991354849848_16137100684357
10430838_10152991620559848_1561157167675
1959468_10152991620469848_38884649656232
Bonnet still need some adjusting to get it to fit right but I think they are great!
Subframe is being dropped 2moz which is a bummer but will be fixed in the week.
Ross is over again 2moz gonna chance the shocks on his GFs polo but after that I am hoping this subframe will come off easy and I can then get some other bits done. Fingers crossed for good weather and better luck then I have been having recently!
#441 geoff-d
geoff-d
  • 468 posts
Posted 15 June 2014 - 04:45 PM
How are you fixing Subby ?
#442 lawrie124
lawrie124
  • 1,710 posts
Posted 15 June 2014 - 05:01 PM
And where did you get those hinges from?
#443 leaky
leaky
  • 6,890 posts
Posted 15 June 2014 - 05:51 PM
I'm gonna take it off and get new nuts welded on properly. I'll just annoy myself if I don't do it properly.
#444 leaky
leaky
  • 6,890 posts
Posted 15 June 2014 - 05:53 PM
A company called Minivation if you get some I recommend the buying them the same way I did. Put your card details in and just skip past the bit where it tells you how much they cost.
#445 lawrie124
lawrie124
  • 1,710 posts
Posted 15 June 2014 - 05:58 PM
Good thinking!
Will try and get over next Saturday for a bit of spannering if you are around.
#446 leaky
leaky
  • 6,890 posts
Posted 15 June 2014 - 06:04 PM
Good thinking!
I am at a christening next Saturday so sadly no miniing :(
#447 leaky
leaky
  • 6,890 posts
Posted 17 June 2014 - 10:38 AM
Right well yesterday I was up and out in the garage by 8 in the morning tidying up sorting some bits out. I cleaned up the horn and accelerator pedal and gave them a quick spray in stone chip.
Then Ross turned up and we replaced the front shocks on his GFs polo which took a good chunk of the day.
Then after we had done that the rear subframe came off.
10354073_10152997389599848_5356884105574
Today my old man dropped it to my mates farm with the camber brackets to he can line it all up and weld the nuts in the right place. Hopfully it should be done within the week. My next day off is Monday so hopefully it will be done so I can get it back on then.
Then last night my mate Alex popped over to route thought the garage and buy some bits but we ended up cracking on with the mini and got the new paddle box and accelerator pedal on with out braking any studs and fitting the brakes and clutch cylinders. I think he left about half 11 so I had a long day haha.
I know the subframe coming off was a bit of a backwards step but I kinda feel better knowing its gonna get sorted properly now.
I'm on evenings this week which I hate as I never get much done but I'm gonna try and find some head studs this week and get the head bolted on the engine so I can get it in. I managed to find the oil filter housing and thermostat housing when sorting out the garage so those are all little odd jobs I can get on with.
I think thats about it for now. Cheers.
#448 geoff-d
geoff-d
  • 468 posts
Posted 17 June 2014 - 12:21 PM
if you need any bits head studs or whatever let me know .
i can leave bits like that for you to pick up on your way home in race car
#449 geoff-d
geoff-d
  • 468 posts
Posted 17 June 2014 - 12:22 PM
#450 lawrie124
lawrie124
  • 1,710 posts
Posted 17 June 2014 - 06:51 PM
I I will probably be going to minispares on Thursday if you need some bits.
