Mini Turbo engines...
#16
Posted 13 December 2005 - 10:14 AM
#17
Posted 13 December 2005 - 11:08 AM
hi mate i am in the process and so are a few other people of creatring a 998 turbo the best thing for you to do is go over to turbo minis.co.uk and they have a seperate section on the 998 turbo engines there are two guys wil h and ben h that are running around 130- 140bhp from a 998 turbo so it is do ableAnyone tried a 1 litre turbo engine?
hope this helps mate
#18
Posted 13 December 2005 - 01:38 PM
I don't really want BIG power, I just want something that is quick, and sounds great, hence the dump va;ve on the turbo, and the shortened maniflow exharst!
I won't mind spending a grand or 2 on a decent engine, that can cope with alot of driving not hard as n racing hard, but something that can rev high is, and something that isn't going to blow up in a few thou miles, also want something that will last, save me doin a rebuild every so often!
#19
Posted 13 December 2005 - 02:47 PM
performance
reliability
cheap
#20
Posted 13 December 2005 - 03:25 PM
#21
Posted 13 December 2005 - 03:49 PM
Don't bother with a supertrick head either unless you are going for every last HP. A cleaned up stock non turbo 12G940 has made over 170 bhp and 170 ft/lbs of torque with a T2 turbo.
Good luck!
#22
Posted 13 December 2005 - 05:12 PM
#23
Posted 13 December 2005 - 05:46 PM
Would a 998 be better than a 1275?
What would be the advatnages with either engine, and which do you think would be best on the back of my buggy?
#24
Posted 13 December 2005 - 06:03 PM
#25
Posted 13 December 2005 - 10:59 PM
Wide offset wheels and especially 13" wheels do not help either. I used to have terrible problems even with a non turbo motor until I set my castor properly.
For outright power, the 1275 based engines, from 1071 on up are best. There are more than a few 200+ hp 1293's.
998's are mostly used where competition rules dictate. In hillclimbing, if you use a turbo 1300 then they put you in the same class as 2 litre cars. If you turbo the 998, you are in the up to 1300cc nat asp class. We think the 998 could produce as much as 160 bhp with the right parts. There is already one that puts out 140 bhp with plenty of development left.
#26
Posted 13 December 2005 - 11:05 PM
anyway, back to the topic
#27
Posted 14 December 2005 - 01:28 PM
a 998 turbo, or a 1275 turbo?
#28
Posted 14 December 2005 - 01:50 PM
Thats what i want to do but not on a buggy!
and i soooo want a dump valve as well!!! scare those pesky pikies!!! lol
#29
Posted 14 December 2005 - 04:41 PM
Aye, its me! I still have my old un as well for covert opsaaaaaaahhh, just realised who you are now maga7ine. new username
#30
Posted 14 December 2005 - 05:48 PM
Which ever size block I go for, its deffo having a dump valve.. ok I might lose some psi, but the end of the day, I anit going to lose that much power/weight ratio!!1293 :wink:
I might get a 1293, as they can come ready built, save me fiddling and farting about with getting the right comp ratio on a 998...
