Float Bowl
17 replies to this topic
#1 Msmith3327
Msmith3327
  • 220 posts
  • Local Club: Torbay Mini Club
Posted 16 November 2010 - 08:47 PM
2 questions on the float bowl,
1, The nut securing it to the carb, will it make any difference if this isn't tight. in such as bad running.
2, Is there a way of checking that the float isnt getting stuck.
The reason i ask is i have an ongoing problem with starting and idleing, I have refurbed the carb and the car ran lovely for about a month and now has the annoying tendancy to die at lights it is also being a complete pig to start, again intermitantly but if i take the petrol hose off the bowl ( loosing petrol at the time0 then reconnect it the car will start.
I have elctronic landrover parts in the dizzy, its had new plugs new leads and a new dizzy cap, all the wireing is in good nick.
I am now lost, any suggestions
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 16 November 2010 - 09:12 PM
The bowl is normally mounted on an isolating rubber, it often appears the bolt is loose but in reality it's the rubber that's moving.
#3 Msmith3327
Msmith3327
  • 220 posts
Posted 16 November 2010 - 09:14 PM
Cheers Dan but mine is defo loose i cn turn the nut by hand, will it cause running problems though?
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 16 November 2010 - 09:18 PM
If the bowl is rattling around it will cause problems yes. The needle valve will rattle and jar and the level of fuel in the jet will too.
#5 Msmith3327
Msmith3327
  • 220 posts
Posted 16 November 2010 - 09:20 PM
Cheers Dan will go and tighten it up tomorrow, mine doesn't have an isolating rubber though so when i tighten it up the bowl will be locked solid, will this matter?
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 16 November 2010 - 09:26 PM
Is the carb spacer solid metal or felt/paper/plastic? The idea of the isolation is to keep the float bowl from vibrating and keep the fuel level constant. If everything is rigid it will vibrate with the engine.
#7 Msmith3327
Msmith3327
  • 220 posts
Posted 16 November 2010 - 09:28 PM
off the top of my head Dan i think the carb spacer is metel, guess i need to find a different one then.
Yeh its an Alloy spacer
Edited by Msmith3327, 16 November 2010 - 09:31 PM.
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 16 November 2010 - 09:31 PM
I would, the carb really needs to be isolated from the engine and manifold both thermally and in terms of vibration. I dislike the ally spacers, the card/paper one is best I think.
#9 Msmith3327
Msmith3327
  • 220 posts
Posted 17 November 2010 - 07:57 PM
Ok so i tightened up the bowl this morning and it started on the button, yippeeee i thought problem solved with no money spent.
But alas no, the bowl is still tight but it still isnt idleing and is being a pig to start.
Any more ideas (Dan as you were helpfull last night)
I have noticed that when its playing up and i am in gear, not using the accelerator going downhill i get lots of popping from the exhust.
UPDATE,
I have checked the float and it seams OK, the Jet isn't blocked as i can blow air through it.
I did spray carb cleaner down the air intake and it started and ran, which would indicate a fueling problem but where is the problem if the fuel is ok!!!!!
GGGGGGGGGGGGGGrrrrrrrrrrrrrrrrrrrrrr
Edited by Msmith3327, 18 November 2010 - 01:54 PM.
#10 Msmith3327
Msmith3327
  • 220 posts
Posted 18 November 2010 - 02:07 PM
Bump as i really need to sort this sorted as its a daily driver.
#11 Big_Adam
Big_Adam
  • 7,435 posts
Posted 18 November 2010 - 02:48 PM
Wait, is this a stock of stage 1 car?
As its sounding like the fueling is right out.
#12 Msmith3327
Msmith3327
  • 220 posts
Posted 18 November 2010 - 03:36 PM
Yep Big Adam its a stock 998 with stage 1 fitted, got it fully tuned before L2B where it worked wonderfully for about 3 months and has just been a complete pain since.
If the Fueling is way out, what area should i be looking at to resolve it.
#13 Big_Adam
Big_Adam
  • 7,435 posts
Posted 18 November 2010 - 04:30 PM
If it went quickly, then I'd think something broke more than the mix went out. Is the rubber pipe from carb to back of the engine block aka the breather pipe clear/unbroken?
#14 Msmith3327
Msmith3327
  • 220 posts
Posted 18 November 2010 - 06:00 PM
see below!!!! :thumbsup:
Edited by Msmith3327, 18 November 2010 - 06:02 PM.
#15 Msmith3327
Msmith3327
  • 220 posts
Posted 18 November 2010 - 06:02 PM
I did tighten the pipe thingy that holds the breather onto the carb as it was very loose, this just made the engine really lumpy while cranking but was fine once i got it going!!!
