Door Catch And Lock Freezing?
31 replies to this topic
#16 danrock101
danrock101
  • 2,478 posts
Posted 06 December 2010 - 09:24 PM
yeah that can be a problem, so I don't use my tongue
#17 samsfern
samsfern
  • 5,243 posts
Posted 06 December 2010 - 09:41 PM
I carry a blowlamp:) but a good one costs a lot more than some deicer (I used to be a gas engineer)
do you leave it in the car or carry it everywhere with you? ;)
#18 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 06 December 2010 - 09:47 PM
If your doors are welding themselves to the door seals, what i have done in the past on my work van is smear abit of grease on the rubber seal, and it doesn;t seem to freeze so bad... I don't know if this damages the seal though, so it might be worth seeing if some one comes along and corrects me ;)
Yup oil will eventually degrade the rubber :( You can get rubber and nylon lubricant, that's the stuff to use. Works well on locks as well, incidentally.
#19 danrock101
danrock101
  • 2,478 posts
Posted 06 December 2010 - 09:49 PM
I've just remembered I have left my car unlocked because I couldn't even get the key in or press the button! will have to sort it before I got to bed!
#20 littlemissmagic
littlemissmagic
  • 514 posts
Posted 06 December 2010 - 09:53 PM
i had this problem alot last year and i found that if i sprayed a bit of de-icer in the locks at night before it froze up then it would be ok in the morning ;)
#21 SamuelHorler
SamuelHorler
  • 18 posts
  • Local Club: SWM
Posted 06 December 2010 - 10:21 PM
@DanRock101 I wouldn't worry too much about if you forgot to lock it, I'm sure Jack Frost locked it nice and safe for you, better than welding he does...
#22 danrock101
danrock101
  • 2,478 posts
Posted 06 December 2010 - 10:22 PM
haha well I'm not going out anyway, it's too cold, probably better than mini locks anyway ;)
#23 SamuelHorler
SamuelHorler
  • 18 posts
  • Local Club: SWM
Posted 06 December 2010 - 10:24 PM
Just invested in a £4 keyring AA battery powered door warming thing, although I'm slightly sceptical, but we'll see how well it works when it comes... In the meantime, KETTLE!
#24 me madjoe 90
me madjoe 90
  • 1,238 posts
  • Local Club: Fylde Mini Club
Posted 06 December 2010 - 11:15 PM
Wouldent bother heating your key up to much with a lighter as well they like to go britle snap ;)
#25 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 07 December 2010 - 12:29 AM
Just carry a lighter around with you, if its frozen, hover it under the door handle, being careful not to melt anything lol and that always does the trick for me.
Did i night shift at work the otherday and in the morning i could budge it at all. Had to poor my coffee over it ;)
#26 Chris_R
Chris_R
  • 399 posts
Posted 07 December 2010 - 12:32 PM
If you're ever stuck with nothing to defrost a frozen lock, having a wee on it works! Not so easy for the ladies to do of course, and not recommended if there's lots of people about.
#27 1984mini25
1984mini25
  • 8,785 posts
Posted 07 December 2010 - 01:39 PM
That's ok until you get stuck as well.
#28 Juju
Juju
  • 3,620 posts
Posted 07 December 2010 - 01:40 PM
Don't put any more water into the locks, they'll only refreeze.
A lighter is pretty good at unsticking them. As is vodka. But not the two together. ;)
Hairdryer/heatgun works too, just make sure the heatgun is on the low setting....
This year I have mostly been using friction (rubbing the locks 'n'andles with me hot little hands) and so far, it has worked.
#29 davies145
davies145
  • 170 posts
Posted 07 December 2010 - 02:57 PM
i have the same problem, just leave it unlocked outside my house most of the time and pus the button realli hard lol,
ashley
#30 feybrand
feybrand
  • 1,247 posts
Posted 07 December 2010 - 03:04 PM
the missus has this problem
mostly because she washes the car too often
water of any sort is a bad idea
pre de-icing it b4 it freezes seems to be the best way
