Look what was on the RR when I got there!!!!!
I like!
Posted 18 January 2011 - 08:59 PM
Posted 18 January 2011 - 09:03 PM
Posted 18 January 2011 - 09:28 PM
Posted 18 January 2011 - 09:35 PM
Posted 18 January 2011 - 10:59 PM
Posted 18 January 2011 - 11:09 PM
Posted 19 January 2011 - 03:56 AM
camco are fine, speak to bruce when you phone then, nice bloke.
Posted 19 January 2011 - 08:04 AM
but for tonight... seriously need some sleep!
Posted 19 January 2011 - 08:27 AM
There seems to be a problem with the sender that the VACUUM PIPE that goes into the ECU.
Posted 19 January 2011 - 10:00 AM
Posted 19 January 2011 - 10:08 AM
ecu fixed for 100 quid? £100 will definately get you a hif44 and an alloy inlet manifold off ebay (we have a couple at work we could sell you for less than that) other than that your looking at a new inlet manifold gasket, which is a few quid, and a session on the rollers again.
im not totally syre if you will have to do anything with any wiring to the dizzy and coil, but i doubt it. i bet there are tons of folks on here who have converted them.
Posted 19 January 2011 - 11:51 AM
what's sleep??
Posted 19 January 2011 - 11:58 AM
Ok the MAP/Vacuum pipes come out of the inlet manifold, through a fuel trap and into the ECU.
99 time out of a 100 its this pipework and its connections that play up.
The sensor in the ECU can play up but rare.
What testing did the RR guy do to pin point the MAP sensor?
Posted 19 January 2011 - 12:37 PM
Posted 19 January 2011 - 12:41 PM
I don't know the Spi ECU, does it have an internal MAP sensor?
If so and that's the error code that it gives then should be an easy fix. I would presume it's just a case of opening the thing up and soldering in a new sensor. If the MAP sensor is external, as is common, then it's even easier.
Saying 'it's the ECU' is not much help, if the ECU was properly FUBAR then the car wouldn't start.
What I would do is swap the map sensor (or get someone to do it if you don't have the tools/skills) and if that dosen't work start look elsewhere.
