when he connected it up, it told him that the sensor was MAP sensor was not working, he then checked the filter etc. followed the pipes back through to the ECU, I have replaced the pipes so I know they are not split or broken...
Ok I doubt it would throw a code to say the MAP sensor wasnt working,
it would be reading at 100 which is (to the MEMS) - atmospheric pressure. The pipes and the connections can be tempramental in that if fitted wrong (pushed on too far), it will block the pipe.
It would have been nice if he were to attach a vacuum pump to the map sensor and create a vacuum, this should then register on the reader and match the vacuum being pulled by the vac pump (mityvac is what i use). This would prove the sensor one way or another.
It is internal yes.I don't know the Spi ECU, does it have an internal MAP sensor?
