Thanks for the reply.
So I also need to get the alarm e c you from the same car too? Where is that and where would I Find it?
J
Its inside the car, behind the dash. (Passenger side I think)
Posted 26 January 2011 - 01:35 PM
J
Posted 26 January 2011 - 01:56 PM
Posted 26 January 2011 - 02:05 PM
J
Posted 26 January 2011 - 02:19 PM
J
Aye, that where mine be. Next to the glove box. I know because I took it to bits to wire in my central locking harness. Remote central locking ftw!
Posted 29 January 2011 - 11:50 AM
Posted 29 January 2011 - 12:47 PM
Posted 29 January 2011 - 12:55 PM
Edited by Sprocket, 29 January 2011 - 12:56 PM.
Posted 29 January 2011 - 01:08 PM
I have yet to come accross a faulty MAP sensor in the ECU. The norm is that the small black pipes are either disconnected, blocked, or split.
Check that these small pipes are connected properly and make very sure that none of the elbow ends are split!. Pipe should run from the back of the manifold, to the fuel trap at the side of the throttle body, then from there to the ECU.Blow through them and make sure they are clear. If you still have the airbox, make sure that the red pipe is also attached to the rear of the manifold and the vacuum valve on the airbox, if you have the K&N, either blank off the stub at the back of the manifold that the red pipe would have attached to, or plug the open end of the red pipe.
One other possability that can cause this is if the clutch has been replaced with an AP clutch rather than a Valeo resulting in a a change in crank position sensor reading.
Get it on a code reader, and ignore any of the fault code diagnosis menues, they are useless. Post up the live data for TPS, MAP, ignition advance, stepper position and whether lambda volts are fluctuating or fixed high or fixed low.
Posted 30 January 2011 - 01:17 PM
Posted 30 January 2011 - 04:21 PM
Edited by Sprocket, 30 January 2011 - 04:23 PM.
Posted 02 February 2011 - 12:05 PM
Ah Ok then, this RR guy knew what he was doing then, since the computer told him so.
I doubt that the ECU is to blame since you have had two on this car and still got the problem. This to me indicates the fault is on the car. At idle the MAP sensor should be reading somewhere around 500mmHG vacuum. if its not, fit a vac guage and check that the MAP sensor is infact reading the same or similar value, if it is and the vacuum is dramatically less than 500mmhg, there is a problem elsewhere. If the vacuum is getting towards 300mmhg, the idles will start to suffer.
Check the ignition advance reading, it should be 15 degrees + or - 5 degrees at idle, if it is any more or any less, there is an issue with the stepper motor, whether it is just 'out of tune' or whether it itself is faulty. ignition advance less than 10 degrees tends to lower the vacuum in the manifold. A major air leak can also create these symptoms.
Basically, get the car plugged into a diagnostic and post up the data requested so that those who have experience with the mini can help direct you to the problem. without actual figures, there is no point anyone speculating any further.
Also picking up on what Icklemini has already suggested, is that pushing the ends of the pipes on too far can block them off. This is especially true if the wrong type of 'elbow' has been used in the wrong place.
The SPi needs tuning but not in the manor most will ever consider, and when the system is out of tune, all sorts of symptoms appear.
As for Camco88, I can recommend them. They are local to me and have used them in the past for other things. They are a Network500 agent, and have the facilities to fully diagnostic check all the inputs and outputs of any ECU via a central computer database. Simply put, they plug the ECU into a machine that runs tests to determine any faults. It is NOT hit and miss, it is definative.
Posted 02 February 2011 - 07:53 PM
Posted 03 February 2011 - 10:49 AM
I am sorry but without the actual data I requested or without looking at it my self, I cannot begin to help any further.
Edited by 1995 MK2 IOM, 03 February 2011 - 10:52 AM.
Posted 03 February 2011 - 10:52 AM
Edited by 1995 MK2 IOM, 03 February 2011 - 10:53 AM.
Posted 08 February 2011 - 09:48 PM
