anyone know what the problem could be given the figures?
TPS - 0.5 V at tick over - 3 v open throttle
MAP when the engine is:
1. off is 1000MB
2. Idling is 260MB
3. At 3000 rpm - 2500MB - ignition timing goes down to -25 at this point too
4. with VAC pipe disconnected - at 3000rpm - 1500MB
Ignition advance - 15 degrees going to -27 degrees
Stepper position - T.O varying, 116 with revs
Lambda fluctuating from 200Mv to -750Mv
J
"new" Ecu... Spi
1995 MK2 IOM
, Jan 25 2011 11:19 AM
32 replies to this topic
#31
Posted 12 February 2011 - 07:59 PM
#32
Posted 13 February 2011 - 04:08 PM
Yep as expected - 1000mb is pretty much atmospheric pressure, so with the engine off this is right...1. off is 1000MB
Yep as expected - the 'suck' on the engine is creating the vacuum and lowing the pressure to, in this case, 260mb2. Idling is 260MB
Most odd! - Its now saying that there is basically 2.5 times atmosperic pressure in the inlet manifold... You got a turbo??3. At 3000 rpm - 2500MB - ignition timing goes down to -25 at this point too
Would also expect the ignition timing to retard like it has as what is being reported is a load of air going in!
Get a vacuum pump on the MAP sensor and pull a vacuum and read off the results... It shouldnt ever go above 1000mb (atmospheric)
#33
Posted 13 February 2011 - 06:02 PM
no turbo... the guy at the garage was saying that my car is behaving like its supercharged! (not really possible with my set up!) does make me wonder if I had an after market ECU... and the engine is doing what it is doing... it'll fly?!
Will get a vacuum pump on the Map sensor and see what happens (back to garage)
J
