Shocks Sit Deiffrent Heights....why?
80 replies to this topic
#76 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 03 March 2011 - 09:29 PM
someones recommended spax to me before, ill assume theres 10 diffrent types then :)
there doesnt seem to be much diffrent in price of them to be honest
how long do adjustable take to settle? i heard you had to keep adjusting them on and off for a couple of months?
to settle? instantly.
you only need to adjust them until you are happy with the 'ride'
#77 Remylebleu
Remylebleu
  • 709 posts
  • Local Club: On my ones :)
Posted 06 March 2011 - 08:52 PM
oh so once i set them where i thinks best they wont drop slightly? (i heard they dropped nearly an inch after fitting to "settle" themselves)
#78 Cerberus
Cerberus
  • 989 posts
Posted 06 March 2011 - 09:27 PM
Its the rubber cones/doughnuts that settle.
You only need to adjust the shocks till your happy with how they're performing, which if your like me, may take ages, :D
#79 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 06 March 2011 - 10:02 PM
The dampers do not change the height of the car they purely dampen bumps etc. See previous replies:
Cerberus - As has been said though, the dampers have no effect on ride height. You can put the car down with no dampers on, all they do is damp the suspension.
bmcecosse - The only parts that affect the height are the rubber cones (and possibly the plastic cup if damaged) - the fruit machine lads will know what to do!
Me - The shocks/dampers have nothing to do with the ride height, although it does seem that these have failed to some extent as they are leaking.
me - The rubber springs are what carries the weight of the car, just like a set of coil springs on a modern motor.
in your "what happens when i take teh dampers off"
ibrooks -The shock absorber does not support the car - the springs do that. The shock absorber simply applies a bit of control to the rate at which the spring can expand and compress. The shock won't have any effect on the ride height of the car.
in your topic - "front ends too low"
bungle - shocks don't change the suspension height
I think once you have the parts in your hand and ready to fit it will become more clear.
Edited by minisilverbullet, 06 March 2011 - 10:03 PM.
#80 Remylebleu
Remylebleu
  • 709 posts
Posted 07 March 2011 - 06:23 PM
so i should just fit the parts and see what happens? :)
how long do parts usually take to arrive from minispares?
#81 Remylebleu
Remylebleu
  • 709 posts
Posted 11 March 2011 - 05:10 PM
got the mini back from the garage today.
fitted new cones, hilo's, knuckles, engine mounts, front subframe mounts....total £280
everything appears fine......just need my wings welding now!
thanks for all your help
