Project 850 X
277 replies to this topic
#1 minimuk
minimuk
  • 1,946 posts
Posted 25 February 2011 - 01:23 AM
My first mini, and of course it will be for my son's 18th (3 years to go) but I will have a go too!!
Bought the mini in September 2009, looked "good", engine started and was ticking over, but could not engage any gears. no brakes. but that was only the beginning.My mate steered the mini into the garage,
and the mini would not come out of there for another year in the end
Attached File  DSC00827_day_two.jpg   21.51K   42 downloads
The 998cc engine project starting in October 2008,............ The clutch was worn and needed replacing, so I decided to do the whole lot, in 3 month,...... I am a bit faster now though!!
Attached File  DSC00854_edited.jpg   24.93K   33 downloadsAttached File  DSC00857_edited.jpg   24.48K   32 downloads
Attached File  DSC00906_edited.jpg   18.72K   16 downloads
Attached File  DSC00927_edited_gearbox_bits.jpg   20.38K   14 downloadsg]
after replacing the 3 main bearings in the gearbox as they where shot, all the crank-shaft bearings (Shells), water-pump etc. and a good clean-up, the rebuild started;
Attached File  100_2111_edited.jpg   18.71K   24 downloads
Attached File  DSC00951_edited.jpg   41.52K   31 downloads
and then ready for the bench test one year on, all good!!
Attached File  DSC01448_edited_engine_complete_and_tested.jpg   20.04K   55 downloads
Body survey next, it all looks to good to be ok, and then,.. I decided to find out what was wrong with the nearside doorstep,...it dropped a bit. That will be tomorrow!!
Edited by minimuk, 19 May 2011 - 08:19 PM.
#2 darky32
darky32
  • 272 posts
  • Local Club: Not yet !!
Posted 25 February 2011 - 08:45 AM
Great work keep the updates coming, it looks a clean and tidy car
#3 bcjames
bcjames
  • 2,728 posts
Posted 25 February 2011 - 09:10 AM
Looks great, im growing rather fond of blue minis! Especially with a bit of BMC green!
#4 minimuk
minimuk
  • 1,946 posts
Posted 25 February 2011 - 10:01 AM
thank you,yep it does "look like a tidy car, the engine was not that bad. but the body work,..........
#5 minimuk
minimuk
  • 1,946 posts
Posted 25 February 2011 - 10:03 AM
I don't know whether the blue and BMC Green engine works, will know soon when I drop the engine back in.
#6 bcjames
bcjames
  • 2,728 posts
Posted 25 February 2011 - 10:13 AM
Depends on your blue really, the classic ones seem to sit well with the green, maybe not so much the modern blues :thumbsup:
#7 minimuk
minimuk
  • 1,946 posts
Posted 25 February 2011 - 12:43 PM
can always change the car color to suit the engine,.......nah will be fine I reckon. Doing the drum brakes at the moment, pain in backside, new cylinders and pipes, all bled and still loose pressure. Yellow band master cylinder had and overhaul,too.
#8 minimuk
minimuk
  • 1,946 posts
Posted 25 February 2011 - 09:14 PM
today I collated some initial body survey pictures
Heal board,..... after the subby stayed on the floor while I jacked up the mini, I do wonder sometimes,....
First few cuts in the mini and that was the start of every day 1 hour at it......
Attached File  DSC00994_nearside_doorstep_first_cut_in_mini.jpg   23.49K   27 downloads
I was not wrong,...after loosing the rear subby,... does any one of yuo find the trunnion mounting holes??
found a bit of cake tin
Attached File  DSC00098_edited_double_boot.jpg   12.27K   27 downloads
driver side footwell, new panel welded on top of,.....well 3 other panels,...yep amazing.
That is it for today, I had noticed then that the car was carrying six outer sills,2 triple foot wells, and the boot was still there hanging onto,.. well not much.
Previous owner was a genious in disquising.
Edited by minimuk, 25 February 2011 - 09:21 PM.
#9 freemini
freemini
  • 371 posts
Posted 25 February 2011 - 10:33 PM
Great work so far mate keep it up.
#10 minimuk
minimuk
  • 1,946 posts
Posted 26 February 2011 - 09:23 PM
will show some progress tomorrow, from last year!
#11 minimuk
minimuk
  • 1,946 posts
Posted 01 March 2011 - 12:31 AM
After putting in the nearside front floor panel and rear floor panel I started on the boot.
Attached File  DSC00090_editeda.jpg   19.27K   22 downloads
boot bottum nearside corner panel
[attachment=10
8686:DSC00100_editeda.jpg]
Attached File  DSC00101a.jpg   21.61K   17 downloadsAttached File  DSC00103_editeda.jpg   16.46K   19 downloads
then the other side
Attached File  DSC00107_editeda.jpg   14.12K   14 downloads
boot bottum repair strip
More next time
#12 M44K TS
M44K TS
  • 3,104 posts
Posted 01 March 2011 - 01:10 AM
6 outer sills!!!! ;)
Someone's been busy over the years then.
Good progress so far though.
#13 minimuk
minimuk
  • 1,946 posts
Posted 01 March 2011 - 10:40 AM
yep 6, 3 on each side one over the other last one was the BIG 9" one holding them all toghether, same with drivers footwell, Spare tyre well etc. Just a special case!!
Yep 2010 was a great year, after that not much surprises me anymore.
#14 minimuk
minimuk
  • 1,946 posts
Posted 01 March 2011 - 11:43 PM
Carrying on in the boot area
Attached File  DSC00157_editeda.jpg   17.13K   21 downloads
nearside outer wheel arch tacked in
Attached File  DSC00160_editeda.jpg   13.87K   19 downloads
and a lick of primer
wheel arch offside removal
new rear seat marked
little bottum repair piece
offside seat repair and arch
nearside seat repair
new rear seats and arches, done
strenght at rear end again, continiue with boot
Attached File  DSC00042a.jpg   16.05K   20 downloads
I am afraid that's it for today, see you next time
#15 minimuk
minimuk
  • 1,946 posts
Posted 02 March 2011 - 11:52 PM
12th April 2010
And on with finishing the boot, looking good and well happy
Attached File  DSC00055_editeda.jpg   11.45K   21 downloads
starting to replace offside rear floor panel, came across crossmember,..not good
after a bit of grinding and cutting, old floor removed and ready for new piece
new panel cut to size with 10mm overlap and made inner sill on rear bin
tacked in rear floor panel and cross-member repair piece
Attached File  DSC00070_editeda.jpg   15.25K   16 downloads
all primed ready for next part, now I am starting to enjoy this
and then I found this,....."driverside front floor panel present" Can anyone tell me why in the name of ...... will someone weld and new panel on top of this mess, he needs to see a doctor!!!
Attached File  DSC01028_editeda.jpg   14.77K   19 downloadsAttached File  DSC01034_editeda.jpg   21.64K   26 downloads
Attached File  DSC01035_editeda.jpg   23.15K   19 downloads
What I have learned with this, being my first project, every day I get a new challenge, I never got fed-up though
more tomorrow
