Project 850 X
277 replies to this topic
#31 darky32
darky32
  • 272 posts
  • Local Club: Not yet !!
Posted 24 March 2011 - 04:24 PM
Fantastic work the car looks stunning... and i must say i do like the twin exhaust
:thumbsup:
#32 minimuk
minimuk
  • 1,947 posts
Posted 24 March 2011 - 05:21 PM
:thumbsup:
cheers, i must say, putting the car back together, does test my patience a bit now and then, but will get there in the end. Twin exhaust, I used my judgement to attach it the way I did, not many piccies about on the web or on the forum to use as a guide line, but it does look good.
#33 miniallsort
miniallsort
  • 4,723 posts
Posted 24 March 2011 - 09:13 PM
NICE MINI MATE
#34 minimuk
minimuk
  • 1,947 posts
Posted 25 March 2011 - 04:34 PM
NICE MINI MATE
cheers, appart from the "headlining" it is a pleasure to put it back on the road again!
#35 minimuk
minimuk
  • 1,947 posts
Posted 29 March 2011 - 05:54 PM
It seems to me that wen it goes wrong it seriously does, headling,......first time......last time!!
I thought it might be a good idea to cover the A-post's, B-post's and rear post's as the interior will be red and black
I just hope when I put the seals in and windows I can get rid if the wrinkels
Attached File  DSC01733a.jpg   56.48K   32 downloads
Unless someone on here has a better idea
#36 barrakuda
barrakuda
    Starting My Mini Up
  • 2 posts
Posted 29 March 2011 - 08:24 PM
I have read this topic a couple of times with great interest, my resto is not in such a bad condition & won't be getting quite the same care and attention but this is definitely an inspiration. given me back a bit of will to get started again as it has been about a year since I really did anything.
excellent work. hope the headlining works out ok, thats one part I do not want to do!
#37 minimuk
minimuk
  • 1,947 posts
Posted 29 March 2011 - 09:53 PM
thanks for your comments, I could not imagine myself leaving the mini for a certain time, I spend the last 18month, everyday at least 2 hours on average with him, on top of that I have this other project running on here. It all becomes so absorbent in time, putting this one back toghether is as much work then the total body overhaul and engine refurb, any wrong steps is rather irritating, and it got to be right. If the headling does not look good, I will get someone to do it again for me,...we will see.
I hope you get back to your project and have fun doing it, there are a lot of good treads on here, where passionate induviduals spending lots of time in garages!!
Good luck and thank you for watching
Edited by minimuk, 29 March 2011 - 09:54 PM.
#38 Pitcrew6464
Pitcrew6464
  • 1,673 posts
Posted 30 March 2011 - 11:22 AM
Massive progress! love the photos, great colour too!
#39 lourens
lourens
  • 84 posts
Posted 30 March 2011 - 07:38 PM
Great Project... Sorry I am only getting time to read it now :techsupport:
#40 minimuk
minimuk
  • 1,947 posts
Posted 30 March 2011 - 10:27 PM
thanks, this is my first project started September 2009, my first welding was February last year, as mentioned to you b4, once you got the hang of it, you loveit.
This project I hope to have on the road in 3 month. the Electro-plating ,you introduced me to, I will use on my other project on here.
#41 minimuk
minimuk
  • 1,947 posts
Posted 02 April 2011 - 11:33 PM
Well the headlining, I have worked out what I did wrong in the first fitting stages, I did not center the lining enough, further, the sleeve(s) in the lining, where poles glide through should be cut back 4"-5" on each end and not 3", so when you pull it tight it will not be held back by the too longer sleeve and create wrinkles, for those of you who have done lining before, you might have stumbled over the same isseue and have learned from it. Well I certainly did!!!
I decided to cover the A-post's aswell as the B-post's, it will look better with the red interior and dark-blue body paint, here are a few pictures, you will see I used bits of the old seal's to hold the lining in place till the glue is dry. by the way I have used glue stick and spray, because you can't use spray everywhere unless you want to clean you new body-paint every time you spray.
Attached File  DSC01748a.jpg   40.95K   12 downloads
Door seals and rear quarter window seals ariving on Monday, will look better once those are in.
#42 luke666222
luke666222
  • 158 posts
  • Local Club: Crewes Missiles
Posted 03 April 2011 - 08:39 AM
A really nice mini you have there!
#43 minimuk
minimuk
  • 1,947 posts
Posted 04 April 2011 - 04:22 PM
Thank you, getting there slowly,
few piccies today after minispares send me the seals for the doors and rear quarters, it has made a diference and pulled most wrinkles out,
a bit more tweeking but looks fine.
Attached File  DSC01751a.jpg   46.15K   7 downloadsAttached File  DSC01752a.jpg   36.92K   7 downloads
Attached File  DSC01753a.jpg   49.23K   6 downloadsAttached File  DSC01754a.jpg   44.11K   6 downloads
doorseals are fine fit but can't close doors yet, then again doorlocks not in yet, I suppose the rubber will mould itself to shape of door after a little while. windows next week!!
#44 ross11380
ross11380
  • 172 posts
Posted 04 April 2011 - 06:21 PM
Looks well good mate, well done.
#45 minimuk
minimuk
  • 1,947 posts
Posted 11 April 2011 - 10:00 PM
It has been a while, as work is rather busy, I haven't been able to do much. To be honest it is not good being tired and try to do a nice finishing job on the mini, so you need to take yr time and do 1 job at the time and being well prepared with all the bit's you need.
Last week I fettled with the head lining and seals, today I managed to put back in the rear quarter glass and the door mirrors.
Those mirrors,.....had to borrow a nut-rivet tool to put the M5 rivets in, looking good but it was a bit of measuring and had to be lined up on the top door rim. Masking tape, marking, pilot drilling, grease rivet, then crimp and well,... mirrors on. It did not feel good to make holes in a newly painted door!!
Attached File  DSC01755a.jpg   61.66K   9 downloadsAttached File  DSC01757a.jpg   42.32K   8 downloads
After all that gave the car a wax pollish, then prepared the door handles and fittings for tomorrow, will get new gaskets for the handles from M-spares.
went to se the body shop today too, checked the sand-blasted wheels today, looking fab, they will get silver sprayed with a bit of pearl, and lots of lacker. Bonnet and Bootlid should be finish end of the month. Need to get that engine in,............
