Got quite a bit done on Friday and some of Saturday:
- Found out the clutch cable popped off because the split pin was missing, refitted pin and all working now.
- Adjusted clutch cable.
- Adjusted handbrake cable.
- Adjusted auxiliary belt.
- Decided to refit the rear seats as the bottom cushion can be lifted foward so the back seat can be laid flat. Should be enough space for luggage still.
- Checked the washer bottle for leaks, turned out the pipe had just come off and the motors aren't working. Currently looking for new washer motors.
- Fitted new exhaust clamp and exhaust sealant, no longer blowing in the middle pipe.
- Bought spare clutch cable incase this one fails.
Think that was everything.
Edited by Mini_Magic, 24 April 2011 - 11:24 PM.
