My 1989 Mini City E Kad Rebuild
427 replies to this topic
#61 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 22 June 2011 - 05:40 PM
I never said that the mini crank was that good, all I said was that you should be fine upto around 200bhp.
Swiftune have gone to the effort because there a great company, they wouldn't be so good if they weren't constantly developing there products.
I'm not saying your wrong I was just saying that you have other options available.
Ben
#62 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 22 June 2011 - 06:12 PM
Well we will agree to disagree, as i dont agree with anything you say
#63 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 23 June 2011 - 10:53 AM
Build looks great.
Without adding fuel to the fire, Turbo nick on here, has a 200bhp engine which he used to drive daily and if I remember, did around 30,000 miles in.
Standard bottom end on it. Nothing wrong with building a strong engine with decent crank though.
Edited by mini_mad69, 23 June 2011 - 10:54 AM.
#64 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 23 June 2011 - 02:02 PM
Im not getting into this arguement again, but it doesnt make it right just because someone else is doing it
Thanks for the the comment about the build hopefully things will start coming together soon
#65 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 24 June 2011 - 02:43 PM
leaving the Steel crank conversation behind ive got a little bit of exciting news and KAD have sent me some photos of the engine at its current state.
Alloy cylinder head needs porting and on the pic is just in its basic state
Pistons need machining
Rods need balancing
Attached File  Kad_engine_1.jpg   172.34K   145 downloads
#66 ministar
ministar
  • 835 posts
Posted 24 June 2011 - 03:26 PM
Look at that head!!!!!!! O_O
#67 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 24 June 2011 - 05:02 PM
Hopefully get some good power figures and good reliability!
#68 george91
george91
  • 883 posts
Posted 27 June 2011 - 07:09 PM
It looks good, whats the spec? Like bore, stroke, CR, cams duration, fueling etc, and what are you hoping to get? Also I can see why your using a steel crank, a modded normal crank is good on a turbo motor, but with a high power n/a engine where your going to be revving the nuts off it, it makes sense. Also are they going to fit a 4 bolt main cap? And are you going to be using steel rods? Looking forward to seeing this built. :)
Edited by george91, 27 June 2011 - 07:10 PM.
#69 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 28 June 2011 - 03:00 PM
The spec is:
140-145bhp,
1380cc.
KAD small valve 16 valve cylinder head with belt assembly,
L1 inlet and BD3 exhaust cams, 10.5:1 compression ratio
A+ block with four bolt centre main cap, bored and honed
73.5mm flat top Cosworth or Omega forged pistons
Vandervell Competition engine bearings
A+ crankshaft 81.28 stroke
A+ conrods, with ARP bolts
HP oil pump, water pump
Twin Weber 40 DCOE carburettors
Aldon distributor with Ignitor Electronic ignition
MED Ultralite Steel billet flywheel and backplate
AP grey diaphragm pressure plate and clutch
4-2-1 exhaust manifold
Im not using a steel crank or rods as its not necessary until over 150bhp
Edited by MJWarren, 28 June 2011 - 03:03 PM.
#70 ajperry
ajperry
  • 316 posts
  • Local Club: Thames Valley Mini Club
Posted 28 June 2011 - 03:39 PM
looks great man! this is the way i think im gonna go when i start my build. how are you finding KAD? easy to talk to? helpful? I'm thinking about building the 16v head engine myself from one of their kits. look forward to seeing the finished article and how it runs! also, just to be awkward, i really liked that jag green pearl colour too so if you do end up finding out the code please let me know! :D
all the best!
#71 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 28 June 2011 - 04:08 PM
KAD are without doubt the best company i have ever dealt with/will ever deal with. Drop them an email if youve got a question about anything and thell get back to you quickly. I was going to build it myself but they prefer to do it themselves not just because of the extra cost.
There isnt a paint code mate, well not one i could find anywhere. you have to mix a colour to look exactly like it. Ive gone for new mini grey now.
Good luck with your future project
Matt
#72 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 28 June 2011 - 09:39 PM
im converting from direct acting servo to single circuit with remote cooper s servo, this gives me more room in the engine bay.
Cooper s servo is meant to give better braking the problem is the single circuit master cylinder clevis does not fit the later type direct acting pedal, the later pedal is thicker and has a bigger hole. so ill have to make a special part.
And also cleaned up my starter motor, a lot of work went into this
Attached File  IMG_0288.jpg   60.45K   18 downloads
Attached File  IMG_0287.jpg   56.45K   12 downloads
Attached File  IMG_0284.jpg   60.17K   24 downloads
#73 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 30 June 2011 - 05:02 PM
Ordered some bits from Carbon weezel, Most importantly a 16v bonnet!
#74 ajperry
ajperry
  • 316 posts
Posted 04 July 2011 - 08:20 PM
Matt
cool man, good to know! I will be following your thread to the end now! haha
also, glad to hear you've been on Carbon Weezel's website, was gonna recommend them as i spotted the 16v bonnet yesterday while browsing!
It's gonna look ace! :thumbsup:
#75 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 05 July 2011 - 04:38 PM
Attached File  IMG_0295.jpg   51.91K   16 downloads
Attached File  IMG_0293.jpg   52.09K   14 downloads
Attached File  IMG_0296.jpg   66.3K   15 downloads
Attached File  IMG_0294.jpg   79.25K   8 downloads
Just waiting on my car to come back now, starting to get annoyed its been away 17 weeks
