wow cheers for the replies! I had a feeling the old oil debate may spark up from this haha! Anyway im sticking with 20wt60 as its a little thicker at higher temps and it is for classic cars and it contains plenty of zinc etc for the gearbox. I am almost sure it leaks because of high oil temps because it only does it for prelonged high RPM. Just spots a little otherwise if left stood for a while but nothing unusual. After coming back from Fort William tho and chasing nutters from the MTB world cup (which drive rediculously fast) it had spewed oil out of just about every seal by the time i got back to Leeds. Still though it had only gone from max to min on the dipstick, so not too worrying. Normally i only need to top it up once every 800 miles or so if i drive carefully and not at prelonged high RPM. Anyway i think ill get a 13 row cooler with a thermostat so it will shut off when just town driving and only get used when im blasting down the motorways!
by the way I did forget to state my engine spec, its an MG Metro engine with unleaded head, runs very well, all standard and has 10.5:1 comp pistons and mild road cam, stage 1 etc, got 75BHP (ATFW) with 70 ft*lbs torque on RR about a month ago with ignition advance set for 97 RON fuel.
Thanks for replies everyone, very helpful indeed!
Edited by AndrewUK1990, 06 June 2011 - 07:16 PM.
