Petrol leak
Posted 18 January 2006 - 09:19 PM
I first used Optimax petrol about a week ago (before this it's always been the cheap stuff). Someone mentioned some additives which "clean" the fuel system (fuel lines etc.).
In the last few days I've developed a petrol leak for the first time. I only notice this when I park somewhere, and return to my car after an hour or so, to find a "rainbow" coloured trail starting from the car. Could the "cleaning additives" possibly have formed a hole in an old pipe/fuel line or gasket?
I'll put some newspapers under the car tomorrow to find exactly where the leak is coming from, but it would be good to know some possible causes..?
Any help appreciated. Cheers. Guy.
Posted 18 January 2006 - 09:33 PM
Posted 18 January 2006 - 09:39 PM
Posted 18 January 2006 - 09:47 PM
Posted 18 January 2006 - 09:51 PM
fire = petrol
algae/fish or nature preservation for rare species underneath your car = water.
Posted 18 January 2006 - 09:53 PM
Ranbows = petrol, i know had a trail of it when my float chamber stuck openyeh rainbows = oil
fire = petrol
Posted 18 January 2006 - 10:03 PM
Posted 19 January 2006 - 08:03 AM
Posted 19 January 2006 - 09:34 AM
Not a good combination !!! :gasp:
DO NOT put off fixing fuel leaks !!
Posted 19 January 2006 - 10:30 AM
if it is the rear most likely suspet is where the pipe comes from the fuel tank and down through the floor and by the subframe.
The pipe rubs there and the leak appears, so a very easy fix.
2nd point at the front is, open the bonnet and look at the bulkhead/firewall you will see the fuel pipe come up there and go into a pot, the pipe splits there too, again a very wasy fix.
if any of these are split, just renew the lot, it is not a big job and will cost about a tenner or so, but could well save your life... and your mini..!!
Posted 19 January 2006 - 10:45 AM
Posted 19 January 2006 - 11:03 AM
I'm going outside now to put newspapers under the car, to try to track where exactly the leak is. I'll check up in about half an hour or so and post up the guilty suspect!
Guy.
Posted 19 January 2006 - 11:04 AM
It's an SPi by the way, thanks anyway though!a likely place to leak from is the carb
Posted 19 January 2006 - 11:08 AM
Posted 19 January 2006 - 11:32 AM
Well I've just had a quick look at it, and its dripping a clear liquid where Cooper shaz suggested (by the rear subframe on the left).
What's strange is that i collected some drops in my hands and smelt them, but they smelt of nothing!! I think its water?! Surely even a few drops of petrol would smell a bit?!
...also there MAY be a leak from the fuel line, roughly where the cat is. More details later though!
I thikn I'll be replacing my fuel lines anyway now as petrol's not something to ignore. Is there a "fuel line replacement kit" which includes all the pipes and fittings needed..?
Cheers. Guy.
