I am just about to put a sound system in my mini (doesn't have anything in it atall at the moment:()
so i was just looking for some advice on a few things
my setup consists of-
-a terrible ripspeed headunit (this will be changed when money builds up again)
- 2 sets of fusion component speakers (cs-cm60's)
- 800 watt kenwood amp
- 12 inch JL audio subwoofer
I am just about to build a dash board, recover my door cards and build a speaker box setup to go on the rear seat, so everything can be modified to any recommendations by people on here
so where would you position the components
i have 4 of them so i thought two in the dash and two in an under seat speaker board as this would give a nice surround sound feel ? and im not sure where would be best to mount the 4 tweeters :/ ?
the other idea would be to put them all in the front? 2 in the dash, and 2 in speaker pods or something ??
finally
the box i will need to make to mount my sub,
i've read on the internet that a 12 inch sub sealed enclosure will work well with about 2-3 cubic feet of air in the box? does this sounds right? how do you decide between sealed or ported
when i had this sub in my mini, i'm pretty sure i made the box too small, and i just couldn't turn the amp up without it just making a popping ish sound, it was slightly cured by drilling a small 20 mm hole in the side, but it wasn't great.......was this all because of the box not being correct or could there be an actual problem??
any advice would be awesome!!
thanks
Nick
