Started bright and early yesterday, with the most tedious job ever!!!! the sound deadening, took forever!!!
Quite rewarding when you have finished it though,
I was quite shocked to find the floor in more or less mint condition, bar one small spot of rust on the drivers floor pan, which hopefully i can cut out and weld some new aluminium in there instead of a full panel
Then i started on the rear bench, got the hang of the bitumen side by this point and had it off within minutes, but this uncovered some rust spots, but they shouldnt be too hard to rectify. Which again i'll use new aluminium cut to shape which i'll weld in.
After having all the bitumen up, i decided to have a brush around and try and discover some rusty bits,
This is what i found......
Passenger Inner sill
Passenger rear bin
Tiny bit of outer passenger sill, that won't be too hard to do
Then... this was the worse bit covered up by lots and lots of fibreglass
so started digging and found the other side to be the same, so im going to cut the whole back end off.
New rear End
New Rear lower Valance
New boot floor repair section
Whilst i was digging around, i found that where the previous owner had welded new outer sills on, he had created some pin holes (can i just weld a blob on these and grind them down afterwards?)
I knew i needed a new N/S/R quarter, so i decided to look if it was fudged anywhere else, and this is what i found lol....
Heres my new panel for that side
The other side isnt knowhere near as bad but theres enough to change it so orderd a new O/S/R Quarter.
By this point i was getting bored of looking for rust, so moved onto the engine removal and subframe, been stuck with this for ages, went up to see R1minimagic (dale) this morning to pick up a genuine rear subby and he gave me abit of advice that worked
And hey presto.. finally, was funny doing this part seeing my girlfriend trying to help me lift the shell up haha.
Here she is hard at work, sanding the rear subby and getting rid of all the gunk ready to get it powdercoated. Haha, she wasn't happy at either of these pics.
Not very often she helps so thought i'd get a pic haha.
That's all for now, might go and have another bash tomorrow as i'm off work with it being bank hol, but may go and watch Jenson Button in Manchester in his F1 car.
Thanks for reading/looking
Louis
