Mini Cabriolet
106 replies to this topic
#76 leaky
leaky
  • 6,890 posts
Posted 11 December 2011 - 08:05 PM
Not a massive fan of the chrome wheels but those arches look the nuts!
#77 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,154 posts
  • Name: Sean
Posted 11 December 2011 - 08:26 PM
I like it!!
What would finish it off nicely is some chrome trim around the door window frame(like the rileys and coopers)
#78 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 11 December 2011 - 10:06 PM
I was just thinking that yesterday! Will keep an eye out for any for sale.
Fitted the red carpet today, looks great and gives it a more luxurious look inside.
Started cutting the holes for the speakers in the door cards as well.
Edited by Mini_Magic, 11 December 2011 - 10:08 PM.
#79 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 09 January 2012 - 11:52 PM
Been pretty busy over Christmas and New Years, so not had much time for the Mini.
It made it to Wales and back, but did seem to misfire and hesitate a few times on the way back. Looks like the coolant temperature sensor might be faulty, so will be replacing that once it arrives.
Also going to replace the thermostat and gaskets when they arrive, as the gasket has perished and is leaking a little.
Fitted a pair of grille and buttons and quick release bonnet hinges, so now it's much easier to work on the front end.
Next I'll be painting the Metro door pockets black and cutting the holes for the speakers in the door cards.
After that I think I'm going to just leave it as it is for now, as it's pretty much looking how I want it. Sure that won't last long!
#80 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 24 January 2012 - 01:57 PM
Hardly driven the Mini since the last update, as it's been having starting problems.
The earth strap was the first problem, so whipped that out and it was fine for a couple of days.
Then the coolant temperature sensor decided to die, luckily I had already bought a new one to replace it so will be taking off the inlet manifold tonight.
Also fitted the new thermostat and gaskets, but not really had a chance to test the car and see if it's still overheating. Could be related to the temperature sensor, I'm not sure.
Painted the Metro door pockets in gloss black, I must say they look great! All fitted and wired up to the radio now.
Once it actually starts again and it's not dark, I'll get it out of the garage and take some up to date photos.
#81 bcjames
bcjames
  • 2,741 posts
Posted 24 January 2012 - 02:08 PM
Yay for chasing around a cooling issue!!
Are metro door pockets the ones with the speakers built in? If so, what size speakers do they take?
#82 leaky
leaky
  • 6,890 posts
Posted 25 January 2012 - 01:36 AM
Looking again I think I'v changed my mind about the chrome wheels. I think they do kinda suit it.
#83 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 25 January 2012 - 02:01 PM
Yeah they've got speakers, not sure what size they are though.
They look like the same as these ones but now in black...
Edited by Mini_Magic, 25 January 2012 - 02:02 PM.
#84 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 25 January 2012 - 10:51 PM
Took the inlet manifold off tonight and finally managed to get to the coolant temperature sensor and replace it. :D
It seems to be starting and running fine now, but need to take it for a test drive and make sure I put everything back in the right place! :lol:
#85 leaky
leaky
  • 6,890 posts
Posted 25 January 2012 - 11:46 PM
Also I'm still interested in those overrides if you want to part with them!
#86 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 28 January 2012 - 04:49 PM
Test drove it and it seemed to be playing up, it was hesitating under acceleration. Turned out I had managed to knock the pipe off from the fuel trap to the ECU. All sorted now.
Finally took some up to date photos of the interior.
Here's the newly painted Metro door pockets.
I seem to be taking these bits off a lot at the moment!
Needs a good clean at some point.
#87 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 31 January 2012 - 06:49 PM
Bought a new water pump and tie bar, which I'll be fitting this week.
Also treated myself to a new exhaust system. :D
#88 nev_payne
nev_payne
  • 2,249 posts
Posted 01 February 2012 - 07:35 PM
That's quite a lot of pipe at the end, going for noise over power?
#89 Mini_Magic
Mini_Magic
  • 5,747 posts
Posted 01 February 2012 - 09:39 PM
Yup! :D
That photo doesn't even show the link pipe to the cat/de-cat pipe, which is straight though as well! :lol:
Edited by Mini_Magic, 01 February 2012 - 09:49 PM.
#90 1380roadmini
1380roadmini
  • 150 posts
Posted 02 February 2012 - 10:02 PM
looks great
