Mini Mpi Won't Start, Was Fine Yesterday!
#31
Posted 17 August 2011 - 10:04 AM
So it seems whatever happens when it won't start, it's not fuel delivery, it's not sparking at all - ECU/immobiliser not allowing it to?
#32
Posted 17 August 2011 - 10:54 AM
#33
Posted 17 August 2011 - 11:18 AM
#34
Posted 17 August 2011 - 11:23 AM
#35
Posted 17 August 2011 - 11:24 AM
I'm not sure but it sounds like you might be having the same problem as me.
We used to think it was the level of the car as it mostly seemed to happen when the car was facing very slightly up hill but that doesnt seem to ring true any more.
Mine seems to do this mostly after it has been running for a while, for example went to get petrol about 4 miles away and after filling up stopped a few metres away and turned off the engine. After this it would not start and after several attempts over 15 minutes the battery ran flat so had to get it recovered.
I have also noted that 100% of the time after stalling, it will not restart for a good 10 minutes.
I'm going to check the injectors this week to see it they are clogged up and not atomising the fuel correctly.
It's a bit different to your fault but it may turn out to be the same problem.
This sounds very suspect to what I had on my 1997 MPI sportspack. I had exactly what you have said and then it progressively started to get worse. it turned out to be a wiring problem, after a while mine started to cut out every time i put the clutch down. mine was caused by the rubber engine bushes being worn and then when the engine rocked forward it distorted the wiring loomb! .. i put polly bushes on and got a auto leccy to fix up the wires as i know nothing of electronics (if you cant see it it doesnt exist in my mind.. but by god can you feel it
sorry if this isnt very helpful to you greg
#36
Posted 17 August 2011 - 11:39 AM
No worries!
One other thought - did crack the cat really hard on a bump around the time this started happening - just made a big dent in the cat, but didn't seem to upset anything else. Is it possible the impact dislodged some sensor somewhere in the exhaust manifold, something like that? Is there anything vaguely related to the exhaust system or located near enough to the cat that it potentially took a bang that could cause an intermittent fault like this?
#37
Posted 17 August 2011 - 08:14 PM
#38
Posted 17 August 2011 - 08:36 PM
Also, you said the cat had received a large impact, are you sure it has not crushed the fuel pipes which run under the passenger side of the floor? If so, there may not be enough fuel flow/pressure to open the injectors....
Edited by R1minimagic, 17 August 2011 - 08:39 PM.
#39
Posted 17 August 2011 - 08:54 PM
#40
Posted 18 August 2011 - 01:31 PM
#41
Posted 18 August 2011 - 11:18 PM
#42
Posted 19 August 2011 - 02:35 PM
#43
Posted 22 August 2011 - 03:40 PM
i once had and found someone had bypassed the inertia switch with a paperclip across the plug and over time the paperclip rusted through and the car wouldn't start!!!
#44
Posted 29 August 2011 - 01:24 PM
My dad also reckons the crankshaft sensor is high on the list of suspects, because he had *exactly* the same problem with his car, (a H-reg Volvo 940 estate) - same symptoms and everything. Took months and three garages to work it out, but turned out to be a bad cable to the crankshaft sensor. So I need to check the wiring between that and the ECU if problems persist.
#45
Posted 09 September 2011 - 07:23 AM
