Driveshaft Nut Keeps Coming Loose
Posted 10 August 2011 - 12:16 PM
This time it is the driveshaft nut. I went to huddersfield and got a front wheel bearing set as i had a wobble at the front off side corner. I replaced one half of the set of wheel bearings as i thought they looked in good order, but i didn't have one of the washers which sits under the driveshaft nut so used the old one. But after a while it just does exactly the same and works its way loose. The driveshaft nut seems to sit to far on to the thread so that the pin is not completely sat inside the nut to prevent it from spinning. This means that eventually the pin gets bent and the nut becomes loose.
What is it that you knowledgeable people reckon it is? Or do you reckon it is best to start over again and replace everything??
Posted 10 August 2011 - 12:51 PM
Posted 10 August 2011 - 12:58 PM
Is the end of the drive flange worn?
Where abouts on it will it have worn? I read elsewhere when i was searching that this could have something to do with it. I wouldn't mind it being a simple fix like that
Posted 10 August 2011 - 01:03 PM
The opposite end from the studs, you will need to remove it to see.
Posted 10 August 2011 - 01:08 PM
Posted 10 August 2011 - 01:39 PM
Posted 10 August 2011 - 02:35 PM
Posted 10 August 2011 - 05:09 PM
Posted 10 August 2011 - 05:10 PM
Posted 10 August 2011 - 05:31 PM
And check for wear on the cv joint where the bearings run.
Posted 10 August 2011 - 05:38 PM
Posted 10 August 2011 - 07:37 PM
Posted 11 August 2011 - 09:35 AM
You will also need to change your CV or hub depending on were the "slack" is, ie if the outer bearing parts need to be pressed in then the hub is good
If the inner parts need to be pressed on then the CV is good, I would suggest very careful inspection of the CV joint as this is where the wear is more likely to be .....
Posted 11 August 2011 - 11:13 AM
That's not what i wanted to hear. Yet more expense. I'm going to grab myself the tools and have a good inspection around and report back.
Edit, when you say pressed I guess you mean it needs quite a bit of force to fit in and fit flush?? In which case i can't remember the bearing going in being all that difficult. It was the outer one too which i suppose means a new hub (N)
Edited by Duncy H, 11 August 2011 - 11:20 AM.
