1340 Wont Idle On Cyl 1 And 4
#61
Posted 29 August 2011 - 09:09 AM
#62
Posted 29 August 2011 - 09:15 AM
we started with the 12g940 head just eliminated porting to be the idle fault by fitting stock block standard head ended up being a process of elimination job to find faultstill have to refit ported 12g 295 head and electronic dizzy
So whats this then?
Hopefully if you say you now have the correct head and are fitting the correct size exhaust system, you will find a vast improvement. an exhaust exit of 1 1/8 inch as stated recently is most likely not helping at all.
Edited by bigmatt4, 29 August 2011 - 09:17 AM.
#63
Posted 29 August 2011 - 09:30 AM
#64
Posted 29 August 2011 - 07:22 PM
#65
Posted 29 August 2011 - 08:09 PM
#66
Posted 29 August 2011 - 10:27 PM
oil down guides because when i removed the head there was oil in exhaust port 1 and 4 and you could see on the exhaust valve stems and the back of the exhaust valve yet the cylinders were clean and oil free.An 850 head on a big bore block is just madness - it will tell you nothing. Why do think oil was being sucked down the exhaust guides?? I really do believe you should fit the proper head and a single SU carb and get it running nicely like that. If it still won't work - the only factor left is the camshaft.......
As mentiond before 850 head was on lt to diagnose fault ie removing modifications to eliminate that possibility. The 850 head will not be staying on the engine and the camshaft is not the problem we are on our second camshaft we started with a 649 cam and have downsized to a RE13 camshaft thinking the cam was too big for street use.
The 940 head will be refitted this weekend when the new extractors arrive.
the exhaust from the extractors back is 1-7/8 the extractor pipes are only 1-1/8 28mm we are upsizing to 1-1/4 32mm
Edited by bigmatt4, 29 August 2011 - 10:37 PM.
#67
Posted 30 August 2011 - 07:16 AM
Good man... That will make a difference....Im not saying it will cure the problem, but it wont do any harm to have the proper sized exhaust manifold fitted.
Oh!! I also have the RE 13 OT cam in my 1380 and im very happy with the performance of the engine. Its a bit lumpy bellow 2300 revs but then smooths out and pulls very strongly all the way to 6500...It wont idle smoothly at anything bellow 1100 revs and even at that stutters and pops. But remember that the engine WANTS to be reving at at least 2300 revs (coming on cam) and is simply not happy below that rev limit, so you will never get it to behave properly at idle...its the sacrifice we make for the oommph higher up the rev range.
#68
Posted 30 August 2011 - 09:41 AM
#69
Posted 30 August 2011 - 08:09 PM
think you need to read all of my posts i started with the 940 head lots and lots and lots of tests with proper head last effort was trying 850 head . but a thick coating of oil in the ports is a little more than lubricatedThe 850 head has just confused you - throw it away...... Exhaust valve stems NEED to be lubricated - never fit seals on the exhaust stems on a hard driven engine...........
#70
Posted 30 August 2011 - 09:05 PM
#71
Posted 04 September 2011 - 07:35 AM
#72
Posted 04 September 2011 - 07:44 AM
Edited by Yoda, 04 September 2011 - 07:45 AM.
#73
Posted 05 September 2011 - 10:52 AM
note it is from a cold start and it rattles a little til it's warm
Edited by b34k3r, 05 September 2011 - 10:53 AM.
#74
Posted 05 September 2011 - 10:54 AM
Th camera mounting is poor
Edited by b34k3r, 05 September 2011 - 10:54 AM.
#75
Posted 05 September 2011 - 02:57 PM
