And after 15mins in the blast cabinet...
Best tool I've ever bought!
Project Trig - More Fresh Powdercoat!
#796
Posted 19 February 2016 - 09:24 AM
#797
Posted 22 February 2016 - 09:19 AM
Hiya, love your rebuild thread. Can you tell me if the fixed rear windows will fit in the opening window aperture? Ie remove the opening rear windows and replace with fixed
Update!
Had the whole weekend off work so got some odds and ends done on the project.
First up was gluing the front of the headlining in place with help from my mum. Leaving it for a few days to properly set and grip.
Then I got round to sorting a cross threaded brake union. Bought a flaring tool and lots of spare unions just incase I need to do more in the future on my fleet of cars.
Then with the help of my dad the brakes were bled using the tried and tested Gunson Eezibleed kit. Brilliant system!
I also made some adjustable height brackets from scratch for mounting the plate. The plate can be moved up or down about 1-2cm each way which will be good for MOT day Im sure! Properly happy with the look of it as it hides the quite large back box perfectly.
Its held to the brackets by my LED plate bolts. Very clever idea!
Also got my tinted non opening rear windows brand new from P&L Minis. So thats my set complete!
And a special shout out to my mum for making this rear seat!
Fully homemade in vinyl and fake suede with diamond stitching. It looks AWESOME!
Next up is finishing off the tank, installing it after I work out a practical way of mounting it and then try and finally tackle the electrics to fire the beast into life for the first time!
#798
Posted 22 February 2016 - 09:55 AM
Words and stuff
The actual metal aperture is the same on all Minis. The only difference is you need openiong/non opening seals to fit those apertures. Non opening has less chance of leaks in my opinion.
#799
Posted 22 February 2016 - 10:14 AM
Words and stuff
Thanks for your help. I have always thought the fixed type should seal better. I assume the glass is different too?
#800
Posted 22 February 2016 - 10:56 AM
Words and stuff
Yeh non opening has larger panes. Opening have metal surrounds.
#801
Posted 24 April 2016 - 09:02 PM
Long overdue update!
#802
Posted 24 April 2016 - 10:16 PM
Know the feeling about job cuts! just managed to keep mine with Amec FW by 5 points in a scoring process.
#803
Posted 25 April 2016 - 07:49 PM
Hello,
What splits have you got?
Posted 26 April 2016 - 08:16 AM
Looks like my job is safe but my wage will be getting cut
Hello,
They arent Mini splits sadly (or I would be fitting them to Trig!) but for anyone with 5x114.3 jap fitment wheels, please get in touch to buy some super rare wheels haha!
#805
Posted 13 May 2016 - 12:47 PM
Well I still have no spare money buuuut I felt sorry for the car sitting there unloved and unused and as its till insured I want to get it back on the road.... The main thing keeping it off the road is the gearbox. It jumps out of 2nd (common fault) struggles to go into third and jumps out of 4th (which isn't fun when you're cruising at 80mph and the revs suddenly start screaming!).
Thankfully I have the original box that was attached to the 1275 (using the box from the 998cc engine at the moment) which has a fault where it wont select 1st or 2nd, which I think is down to a selctor fork/shaft issue.
So last night I started stripping the spare box to see whats going on inside and to get a list of parts to replace, as I want this to be an 'as new' build.
Looks pretty ropey having sat in a plastic bag round the back of my parents shed for about 3yrs, however all the oily bits are rust free which is surprising!
Diff housing looks like moisture has crept in between the metal and the paint, hence the bubbling.
Drop gears are in good condition with no signs of wear so these can be reused. Did consider switching to straight cut drops for all of two seconds. The use the car gets is mainly long drives to shows etc so noise being reduced rather than increased is a nicer idea. Although straight cut drops do sound epic....
Pretty sure these markings refer to the box casing rather than whats inside it but you never know. Im going to clean up the cast marks on this as well as it looks rough as *******.
Speedo drive full of crap. Thankfully the gear that connects with this is plastic so this crap wouldnt have been crushed too badly or caused much damage but still...pretty bad.
Bottom of the casing/sump. Lots of debris in it.
This was rattling around in the sump...hence why I couldnt select 1st or 2nd.
I guess a 25yr old cast metal part is allowed to fatigue over time. Pretty clean shear as well. Hopefully a cheap part new or second hand if not.
The end bearing on the drop gear side was broken although still spun freely, the plastic had cracked for reasons unknown.
Speedo drive housing was a state so I set about blasting it clean again. Just need to scrape off the remaining gaskets and then reblast it.
Removed the diff as well but hands were oily so didnt get any pics of that. Need to count the teeth to confirm what ratio of final drive it is.
Enjoyed getting back into Mini stuff for a change. Hoping to get the box fully stripped over the weekend for inspection and then get the casings off for powdercoating. :)
#806
Posted 23 May 2016 - 05:19 PM
Fully disassembled the gearbox last night and started going through cleaning and blasting everything today. Looks like it's in good condition throughout, minus the broken collar on the selector pin. Planning on replacing a few common fault parts like bearings and potentially a cross pin diff (to future proof the box if I do eventually modify the engine too).
#807
Posted 05 July 2016 - 12:05 PM
My overpriced and totally pointless titanium bolts arrived after a short delay due to broken tooling. They are ace.
Will give them a polish up before fitting
Got some time to get stuck into this last night again. Still smoothing casting marks from the gearbox casing but as that is boring to do I started to strip the bay ready to remove the engine.
Heres the current state of the enginebay.....what I would call a complete mess.
Also diagnosed my **** ride quality issue. Suspension cones have collapsed. Set of new ones are only £160 which isnt bad as they have lasted 7yrs.
Obviously had to take the exhaust manifold off and its turned a lovely shade of rainbow with the heat. Polishes up bonny too.
All that remains is to drop the fluids, disconnect the driveshafts and its ready to rip out. That will mean I can get the other casings from the flywheel/clutch side, along with lots of other bits, powdercoated at the same time.
Got a list of gearbox parts I need so will try and get them ordered after payday.
Feels great to be working on the actual car again. Lots of ideas developing as I go so should be good fun
#808
Posted 05 July 2016 - 04:44 PM
Looking good, you're mum has done a fantastic job on those seat covers.
#809
Posted 05 July 2016 - 05:38 PM
Thanks! She's got skills. Retiring thematic forever but results speak for themselves.
#810
Posted 05 July 2016 - 06:33 PM
