The 89' Mayfair - Aka Two (The White One)
338 replies to this topic
#331 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 20 January 2014 - 08:02 AM
Looking good buddy those panels look a good fit keep it up :D
Dan
#332 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 20 January 2014 - 09:42 AM
Cheers buddy :thumbsup:
#333 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 02 February 2014 - 08:44 PM
Been fettling with the doorstep and rear quarter panel this weekend, With it being a magnum doorstep as you can imagine did not fit! so i sharpened all the folds to begin with.
The curved ends of the doorstep were not even close to fitting so I cut the front to give me the correct shape and just needs a small filler section to close the gap.
The back of the doorstep was so bad i decided to cut the full back off and use an original section from my little panel donor.
All of the rust was cleaned off and I cut out all of the rot and welded a new piece in onto the first edge
Drilled out the spot welds
Picture after I fabricated and welded in the repair
Quarter panel fits perfect
Not far off welding it all up now. Got to trial fit the door, get all the seams zinc primed, paint the inaccessible parts in 2k body colour and they can be welded.
:highfive:
#334 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 02 February 2014 - 09:45 PM
Great work, The magnum door step panels are crap, mine was pretty much the same :mmkay:
#335 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 02 February 2014 - 09:53 PM
Thanks. They are pretty poor, looking forward to m-machines version this year!
#336 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 07 April 2014 - 08:48 PM
Been a while since I updated this but im still working away at it on evenings and pretty much every weekend.
Floor and inner sill is in place
Inner sill strengthener back in place
Gapping
Toe board section welded in because of the rust in the mating flange where it meets the floor
Now engine wise, I have fully stripped the engine, the crank will be getting a re grind to remove the minor marks, new mains and big end bearings, oil pump etc etc, the bores and pistons are in really really good condition so will be checking the ring gaps prior to rebuilding to be sure everything is ok. I am still trying to decide on a diff ratio. Currently has the standard 3.44, but i want the revs down a bit at higher speeds. Its a mg metro 1275 so even changing the diff to say 3.1 i will have enough torque but should still have enough acceleration for what i want.
Will try and update this more often but life at the moment is work.. mini.. shower.. tea...bed.
:thumbsup:
#337 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 07 April 2014 - 08:51 PM
On another note my daily 86' mini passed its mot on saturday, body wise shes getting tired now so she will be sorted after this one.
#338 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 07 April 2014 - 08:53 PM
And also been spending!
7.5" Cooper S brake set up with MS callipers
#339 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 April 2014 - 05:30 PM
Nice work!
