Sound Proofing
#31
Posted 19 August 2014 - 06:12 PM
White Spirits
#32
Posted 19 August 2014 - 06:13 PM
#33
Posted 20 August 2014 - 12:01 AM
I've not had any trouble with flashing tape coming loose but ymmv. When you apply it make sure the surface is completely clean of dust and oils and heat the tape a little - should stick like sh*t on a blanket then.
#34
Posted 20 August 2014 - 06:58 AM
thanks for all the advice - all valuable stuff; I guess I will be melting my brain with white spirits at the weekend (seriously, kids remember any petroleum based distillate can seriously ruin your health)
Just as an update I really like the 'flooring-to-go' rubber mat but they want £45 delivery! Maybe a local carpet stockist could get it for you, but for me its made that source untenable
I am investigating a similar product at http://www.floormats...-transport-mats which comes in several thickness so I have asked for some dB reduction info. If they have it I will report back, looks very similar though and I think it will do the job
#35
Posted 20 August 2014 - 08:11 AM
if you where in Kent i could sort it for you, My dad is a flooring contractor.. :/
#36
Posted 20 August 2014 - 05:52 PM
lol thanks for the offer - I am definitely NOT in Kent
The second choice rubber mat http://www.floormats...-transport-mats have no dB reduction info, but looking at the density of the material I think it is worth a punt - I will report back in a few weeks; I might even do a before and after measurement with my dB meter
#37
Posted 03 September 2014 - 06:37 AM
The best stuff ive found and it actually works is called: duralay kensington deluxe and cloud 9 supercontact 10mm believe me i have alot of choice and out of all the underlays i would say theses are the best
#38
Posted 03 September 2014 - 07:11 AM
#39
Posted 05 September 2014 - 09:13 AM
its the way to go! ive just put the tredair stuff behind my dash and it makes a huge difference its bloody heavy mind but it works!
#40
Posted 05 September 2014 - 03:20 PM
I lied It not cloud 9 its Cosi foam ;) LOL
#41
Posted 05 September 2014 - 04:58 PM
Does all this sound proofing add on alot of weight? I'm going to sound proof mine a bit but it looks like when you do the whole car is adds loads of weight!
Cam.
#42
Posted 05 September 2014 - 06:46 PM
But if you use the lighter stuff like Dynamat superlite or the 2mm silent coat and don't cover every inch of every panel it won't add more than half a tank of fuel would.
#43
Posted 05 September 2014 - 08:37 PM
I'll look into it.
Cam.
#44
Posted 05 September 2014 - 10:08 PM
I think my build thread starts by saying its built to EMMA standard.
I've competed before with my S2000, did quite well finished the season 3rd in my Class in the UK.
#45
Posted 06 September 2014 - 04:51 PM
Well your gear does seem to be far far inferior. I think you need to get down Halfords if I'm honest!
But seriously, 3rd is pretty damn good bro. You're insane
Cam.
