Best Rust Treatment
26 replies to this topic
#16 Pitcrew6464
Pitcrew6464
  • 1,673 posts
Posted 20 October 2011 - 07:50 PM
VACTAN RUST CONVERTER AND PRIMER great stuff put on sheet of metal and left outside last year still looks spot on :D
#17 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 20 October 2011 - 07:59 PM
jenolite is excellent stuff its like jelly
Do they still make the "Jelly" stuff then? All the stuff I've bought in recent years has been a bright pink runny liquid, I did prefer the jelly stuff though.
#18 SA MINI
SA MINI
    Previously known as shaunarmes.
  • 1,001 posts
  • Local Club: yet to join HAMOC
Posted 20 October 2011 - 11:04 PM
Localy there's a very small car shop I go to for all my paints, oils & old parts they have all the old stock ect plus new stock. So I could of bought some old jenolite mines pink but very gooey jelly stuff not runny one bit
#19 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 21 October 2011 - 11:56 AM
Bilt Hamber Deox Gel. THE best product i have ever used. Works so well Ive treated every bit of old metal on the car to it when Ive been refurbing parts. Not the cheapest but my god is it the best! Plus a little seems to go a long way. Water soluble and non toxic too. Brilliant, brilliant stuff!
Clings to any surface no matter what the angle and for really bad rust you can wrap it in cling film for up to 24hrs to really work its magic. One thing I would say is dont put it on for say an hour and forget about it....it will be dried on in that time and its almost impossible to get off again to leave a smooth surface.....thankfully I found this out on something you will never see on my car but still......
Edited by Mini 360, 21 October 2011 - 11:59 AM.
#20 LeaLeaCooper
LeaLeaCooper
  • 412 posts
Posted 21 October 2011 - 12:25 PM
Has anyone used Dinitrol?
I do believe it is more or a prevention then a treatment. . .
#21 govig
govig
  • 339 posts
Posted 21 October 2011 - 12:43 PM
If you don't need the stuff to stick (as in derusting vertical services) then phosphoric acid is cheap at about £4 a litre. Trouble is nobody seems to know how much to dilute it by for the best results.
#22 SAL 821X
SAL 821X
  • 1,890 posts
Posted 21 October 2011 - 12:45 PM
Thought I'd use this thread instead of starting another.
I've stripped my van back to metal and its already starting to get surface rust on it.
Is this stuff ok to paint over large areas of metal or is it just localised stuff?
Thank you please.
#23 jaydee
jaydee
  • 8,565 posts
Posted 21 October 2011 - 12:49 PM
jenolite is rather expensive, the deox gel from bilt hamber is cheaper and a lot of people use them on classics and rally cars..
#24 jaydee
jaydee
  • 8,565 posts
Posted 21 October 2011 - 12:51 PM
Sometimes i put it in a 50% solution in distillated water, seems to react better..
#25 Ethel
  • 26,074 posts
Posted 21 October 2011 - 01:59 PM
Phosphoric acid will be the active ingredient in most, if not all, of these rust converters. Yes you can paint over it, but sand/grind off as much rust as you can before applying it and rinse & dry before priming.
#26 conlad
conlad
    Previously known as ct16mini.
  • 2,054 posts
  • Local Club: Hilltop Minis
Posted 20 December 2011 - 06:10 PM
Thought I'd bring this thread up again as I am unsure as what to buy really.
I want something to PREVENT rust not just to treat it..
It has to be able to be primed over
Cheers for any help :D
#27 charliedurrant
charliedurrant
  • 519 posts
  • Local Club: There isn't one down my way
Posted 20 December 2011 - 06:33 PM
Preventing rust is done by stopping thr electron flow, hence a coating. There is not much more to it than that. The cleaner and more uniform the surface the better the coating adhesion. Hence phosphate treatments and degreasing before painting.
The best coatings are those that are strong and malleable hence zinc and then on to paint which is strong but less flexible and brittle (chips). As with all coatings the hard bits to get to are the most important!
An article which is good in my opinion is:
http://www.calproject.org/pdf/CorrosionProtection.pdf
Charlie
