mini suspension
44 replies to this topic
#1 eddypunch
eddypunch
  • 15 posts
Posted 04 February 2006 - 07:36 PM
i would like to know how to lower the trumpets at the back. ihave got the rear sub frame out but i dont know what to do next.
thanks
ed
#2 RacingGreen
RacingGreen
  • 2,111 posts
Posted 04 February 2006 - 07:43 PM
you can either buy a set of hilos to replace the original trumpets, or u can cut the original trumpets.
#3 eddypunch
eddypunch
  • 15 posts
Posted 05 February 2006 - 11:28 AM
i have cut them but i dont know how to put them back in to the place where they where because there is a big gap.
i have cut them 3inches
ed
#4 Jammy
Jammy
  • 25,397 posts
Posted 05 February 2006 - 11:43 AM
If you've removed 3" from the trumpets you'll now have to replace them. Theres a certain raito to cutting down the trumpets, and it depends on whether its at the front or rear. Off the top of my head its something like 3:1 at the front and 5:1 at the back (double check this though), ie. for every 1mm you cut off the trumpet, it'll lower the ride height by 3mm at the front or 5mm at the back. So your 3" you've cut off will lower the ride height at the back by 15"!!!
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 05 February 2006 - 12:58 PM
woops :rolleyes:
#6 Puddings
Puddings
    Nurburgring Master
  • 1,046 posts
  • Local Club: fabmoc/TMF
Posted 05 February 2006 - 01:04 PM
thats low :saywhat:
#7 RacingGreen
RacingGreen
  • 2,111 posts
Posted 05 February 2006 - 04:36 PM
thats low  :saywhat:
yeah, like through the floor
#8 eddypunch
eddypunch
  • 15 posts
Posted 05 February 2006 - 05:24 PM
i have had a play and got them back to the size they where before so i have cut them 1inch. i have found that the shocks have broke.
#9 RacingGreen
RacingGreen
  • 2,111 posts
Posted 05 February 2006 - 05:32 PM
what do you mean by "had a play", how did you make them longer after cutting them up?
#10 eddypunch
eddypunch
  • 15 posts
Posted 05 February 2006 - 05:40 PM
i have got the longer bit of the trumpet and hammerd a bit of round solid steel (about 4inch long) into it. got the cut of bit and cut that down a inch then hammerd that over the steel bit then put the round bit in the end.
#11 minislapper
minislapper
  • 1,957 posts
Posted 05 February 2006 - 06:07 PM
No No No No. That is far from safe. Go to a scrapyard and get a new pair for less than £5 !!!!!
#12 RacingGreen
RacingGreen
  • 2,111 posts
Posted 05 February 2006 - 06:11 PM
I saw that sort of answer coming when i asked how he made them longer again.
#13 Steve@RetroDash
Steve@RetroDash
  • 1,163 posts
Posted 05 February 2006 - 06:17 PM
oh man does this kind of thing really happen? :saywhat:
he's gotta be on a wind up :rolleyes:
#14 eddypunch
eddypunch
  • 15 posts
Posted 05 February 2006 - 07:19 PM
there are just as good. they dont move one bit
#15 RacingGreen
RacingGreen
  • 2,111 posts
Posted 05 February 2006 - 07:33 PM
You really shouldn't even think about putting them back on your car, they may not move now, but think how much load is on them when installed. not a good idea.
