mini suspension
44 replies to this topic
#16 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 05 February 2006 - 07:39 PM
there are just as good. they dont move one bit
No they are not. Do not use them they will kill you or someone else. Your insurance company won't think they're just as good either. The load the suspension puts on them is massive as said above.
Get some new ones and then get someone else to do all the work on your car from now on.
Initially I was just going to ask why you had removed the subframe in order to do this but now I have so many more questions. I would really consider getting someone else to re-fit the subframe if I were you.
You have to be really accurate when cutting trumpets if you want the car to sit on the road level and be safe from now on.
#17 Jammy
Jammy
  • 25,397 posts
Posted 05 February 2006 - 08:47 PM
Dan, while your on here, can you confirm I got the ratios right on how much to cut off each trumpet? I had a search and couldn't find anything even though I know its been stated many times! :erm:
#18 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 05 February 2006 - 09:02 PM
for what it's worth, i have to agree with those ratios
#19 sirmarky
sirmarky
  • 97 posts
Posted 05 February 2006 - 09:14 PM
throw those old trumpets away & buy a pair of hi-lo's instead , that way you can set up the ride height a needed...
mark
#20 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 05 February 2006 - 09:23 PM
when one of the mini doc's tell you its dangerous it is :wink:
#21 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 05 February 2006 - 09:27 PM
no offence, but you only need common sense to tell you it's dangerous. :grin: :nugget:
#22 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 05 February 2006 - 09:51 PM
:nugget: :nugget: :nugget: :nugget: :nugget: :w00t: :w00t: :saywhat: :w00t: :erm:
#23 Sprocket
Sprocket
  • 7,266 posts
Posted 05 February 2006 - 09:56 PM
Maybe he did use the ratio but the wrong way round :nugget: :grin:
Not funny realy, people could have been killed :sad:
#24 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 05 February 2006 - 10:21 PM
Yes jammy, you got the ratios right. Do you want a badge or something? :w00t:
#25 Jammy
Jammy
  • 25,397 posts
Posted 05 February 2006 - 10:26 PM
Oooo, a badge would be great, failing that a biscuit will do!
#26 eddypunch
eddypunch
  • 15 posts
Posted 06 February 2006 - 04:21 PM
its not to go on the road its a stock car and they brake all the time.
#27 Sprocket
Sprocket
  • 7,266 posts
Posted 06 February 2006 - 04:33 PM
Well if it were me id be building a car to get me to the finish line and not doing stupid things like bodging the suspention which is a sure way of not finishing the race :w00t:
#28 neil_g
neil_g
  • 880 posts
Posted 06 February 2006 - 04:36 PM
*bangs head agains desk in dismay*
:w00t:
#29 eddypunch
eddypunch
  • 15 posts
Posted 06 February 2006 - 04:44 PM
well ive won 6 and came in the top ten almost every time
#30 Sprocket
Sprocket
  • 7,266 posts
Posted 06 February 2006 - 04:58 PM
and what has winning got to do with bodging your suspention :w00t:
