I bought the car with a 3 week old MOT that was issued by Breeze Van Centre, 331 Salisbury Road, Totton, Southampton, SO40 3ZU, signed off by Joshua Stone and it was blatantly crooked. Stevie Wonder would do better job.
All was patched up to look ok for viewing, but after a closer inspection, I found the car was riddled with hidden horrors. For example, The bush for the steering column was broken but instead of replacing it (£5 max) he had put it back together with electrical tape and there was no spleen at the end of the shaft. Steering was fine for test drive but fell apart on the motorway at 60mph. Scary stuff!!! Which brings me to my next point. The speedo is 10mph out which i found out by getting caught in a 40 doing 50. "3 Points or a D.A. Course, Sir." Thanks Sam. The wheel flange had no teeth on the inside and only worked as the nut was done up so tight. The rear brake line had been crushed due to someone jacking the car up in the wrong spot. The front subframe rear mount had been patched up by someone who has no skill in welding (the carpet was glued down with what i can only describe as araldite and the crafty little sod had strategically parked the car over a puddle so i wouldn't check it from underneath. Same reason i didn't check the rear brake line) and ripped out as if it were perorated card and the mount on the other side had broken. The list dose go on and on. But even so, Would you MOT a car with any one of these issues???
I've reported the centre to VOSA and sent photos such as
Anyway, my point is, DO NOT give any of your money to SAM COLE. He is a scammer and should NOT be trusted when it comes to buying cars from him.
Thank you for reading and I hope to save you a lot of time and money.
DO NOT BUY FROM SAM COLE!!!
