Electric Fuel Pumps
31 replies to this topic
#16 jamiestevenbell
jamiestevenbell
  • 637 posts
  • Local Club: DCMOC
Posted 26 December 2011 - 07:25 PM
megajolt is a fully mappable ignition system
#17 danny79
danny79
  • Just Joined
  • 111 posts
Posted 26 December 2011 - 07:34 PM
megajolt is a mappable ignition system.
where did you buy the pressure switch. is the one posted above off rimmerbrothers not the correct one
#18 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 26 December 2011 - 11:54 PM
After looking through the MJ manual and thinking about my install, I can see that a very low RPM setting on one of the outputs is a way of practically doing this, say 200rpm so that the pump will only work if the engine is fired. Injection vehicles have a relay that primes the fuel system when you first switch on the ignition and then cuts it off until the engine fires and then powers up the pump. The SPI and MPI minis as well as many other cars have an inertia switch that cuts the power to the fuel pump in the event of a impact, hopefully preventing fuel spraying all over the place and boom.
My only concern is whether you need to prime the fuel system to fill the carb up before it will start, especially if the car is not run frequently the fuel may have evaporated or seeped back down to the tank, you could then be cranking for ages without it starting. maybe one of the injection relays wired up to the ecu output would allow this to work.
The oil pressure switch may cause the same problem however, but as long as the car does not require priming to start then maybe they would both work fine.
#19 firefox
firefox
  • 1,102 posts
  • Local Club: will find one when on the road
Posted 27 December 2011 - 10:43 AM
I looked for the one in the instructions that i posted, took some finding but found it in the usa postage was long because of Xmas if you order you should get it quicker
and its only $5 http://www.ebay.co.u...984.m1439.l2649
#20 danny79
danny79
  • Just Joined
  • 111 posts
Posted 27 December 2011 - 02:17 PM
would the one from rimmerbrother not have done the same job..
only reason i ask is i Just ordered 2 of them..... doooh >_<
#21 firefox
firefox
  • 1,102 posts
Posted 27 December 2011 - 06:08 PM
Yeah 3 prong that is the link i put on, i liked the look of the one from USA, rimmer bro might be better only time will tell
#22 danny79
danny79
  • Just Joined
  • 111 posts
Posted 29 December 2011 - 08:28 PM
the pressure switch from rimmerbrothers is way off.
thread doesn't resemble anything that will thread into my car anyway. (too big)
have to make up adapter tomorrow in work, something i wanted to avoid.
let me know how you get on with ebay one.
#23 jameslearwood
jameslearwood
  • 525 posts
  • Local Club: ALL ALONE
Posted 30 December 2011 - 01:17 PM
Can I ask a noobie question why install a electric fuel pump?
I was going to do the swap whilst my engine is out as my thoughts are the electric is better and easily accessible for maintenance but am I better off just sticking with the mechanical?
Just a standard road set-up
#24 danny79
danny79
  • Just Joined
  • 111 posts
Posted 30 December 2011 - 02:10 PM
the reason i'm installing an electric pump is i installed a stage one kit and i'm not happy how close the new manifold come to the fuel lines going into the mechanical pump.
easier to route the fuel lines with an electric pump.
Edited by danny79, 30 December 2011 - 02:19 PM.
#25 klivins
klivins
  • 317 posts
  • Local Club: minimania.lv
Posted 30 December 2011 - 02:49 PM
I installed electric pump because its pain in the a*** to get to mechanical with my big hands (should have thought of it before I got the mini really), lol
#26 firefox
firefox
  • 1,102 posts
Posted 31 December 2011 - 08:58 AM
The reason i changed over to electric is i didn't like the petrol pipes to near the exhaust, leaded petrol runs hotter
so to me it was a fire hazard
#27 firefox
firefox
  • 1,102 posts
Posted 31 December 2011 - 09:02 AM
Yeah i bought this one bud, http://www.ebay.co.u...984.m1497.l2648 and the same i didn't like the look of the thread, this adapter fits super, i already had one fitted for my oil gauge, so i needed to double it up
#28 firefox
firefox
  • 1,102 posts
Posted 31 December 2011 - 01:57 PM
Metro Turbo had one of these fitted, the part number is iirc:
Intermotor 51011 Oil Pressure Switch or Unipart GPS134.
where can you get them from bud
#29 jameslearwood
jameslearwood
  • 525 posts
Posted 31 December 2011 - 03:00 PM
right okay thank you
#30 danny79
danny79
  • Just Joined
  • 111 posts
Posted 31 December 2011 - 10:53 PM
From what i can makeout the metro torbo is only a single terrminal switch.
i've been looking at alot of 2 terminal switches but none are in the correct tread pattern for the A-series engine
either that or i'm missing something in order to get them to fit.
from what i can see the tread pattern on the adapter for the oil switch and gauge is 1/8 nptf but the majority of pressures switches are 1/4 nptf.
now the only other problem i can see is all the 3 terminal switch have a warning at 8psi which is very low,(again could be wrong here)
i've found the following 3 terminal switches
ROVER
2000 (SD1) 1982-83
2300, 2600 (SD1) 1977-83
3500 V8, Vitesse (SD1) 1982-87
3500S V8 (SD1) 1976-81
Land Rover 101
