A Productive Afternoons Work........not!
31 replies to this topic
#1 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 03 December 2011 - 07:39 PM
It was a mild winters afternoon this afternoon, so I thought I'd pop outside and sort out a small section of surface rust on the end of one of my sills where it meets the front wheel arch. So...not a big job, just a small section of exposed metal that somehow got missed when the sill was put on recently. It really should have been just a case of wheel off, out with the grinder, then out with the jenolite, cover with zinc primer and then under seal over the top (not the most ideal of repairs, but sufficient enough to keep the salt & moisture out, until I can get around to doing a proper job in the spring)... Shouldn't take more than hour at the very most....
But.....when undoing the first locking wheel nut to remove the road wheel, I felt a sudden crunch as the pins inside the 20 year old locking wheel nut tool sheared off. Now leaving me with four wheels securely locked to the car, with no way of removing them!! :cry:
Not to fear, for TMF is here!!! :thumbsup: Having read various previous threads here on how to overcome this precise dilemma, I had a number of tricks up my sleeve. ;D
First out came the mole grips to try and get a grip of the outside of the nut.... Failed!!... The locking nuts are manufactured with an outer ring that will simply spin if you try and attach anything to it. Next out came the angle grinder to cut the outer ring away, (so that I could get the mole grips onto the nut itself).....Failed!!.... No matter how tight I applied the grips, they came just away when I tried to turn the nut. Next I attempted to grind/file a flat on each side of the nut to allow an adjustable spanner to be clamped on to the nut......Failed!!.... The locking nut is essentially hollow, so attempting to grind a flat, means that you are soon grinding through to thin air!!.... Last resort then..... out comes the welder in an attempt to weld an old spanner onto the end of the nut.... Failed again!! For some reason, despite many attempts on various settings, I couldn't get any weld penetration into the nut.... maybe the locking nuts aren't made of steel... who knows?? But four hours later, all I had managed to achieve was one very mangled and scorched locking wheel nut, that was still locked firmly in place!! >_<
So down to ATS we go, to ask the tyre monkeys there how they overcome this sort of problem. They don't!! So they direct me to a garage on the other side of town where they themselves send cars with such problems to. On arrival there, the bloke laughs at my handy work and produces what is basically a large glorified stud extractor. Fifteen minutes later he had the three locking nuts off that I hadn't tampered with, followed by a further 45 minutes to remove the remains of the "mullered" nut that I had spent the last 4 hours destroying. He then presents me with a £50 bill!! :(
So to sum up.... I wasted an entire afternoon, am now £50 worse off, have a set of alloys that anyone can now easily steal, (meaning I have to now to buy a new set of locking wheel nuts) and still have a patch of exposed metal/untreated rust on the end of one of my sills!! >_<
All in all, a productive afternoons work!! :rolleyes:
Edited by AVV IT, 03 December 2011 - 07:44 PM.
#2 Cooperman
  • 23,326 posts
Posted 03 December 2011 - 07:42 PM
It's a Mini - ******* happens!
#3 minipete
minipete
  • 458 posts
  • Local Club: East Yorkshire MOC.
Posted 03 December 2011 - 07:59 PM
Nevermind we`ve all been there!
#4 Rob-T
Rob-T
  • 45 posts
Posted 03 December 2011 - 08:46 PM
Soz to say it Buddy but I'm glad it's not just me, who'd have a mini ?????
Meeeeeeee!!!!!!
#5 jbs.998
jbs.998
    Previously known as Rockabillypsychosis
  • 928 posts
Posted 03 December 2011 - 09:12 PM
Locking nuts are over rated!!
#6 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 03 December 2011 - 09:20 PM
NO..NO... As an anti theft device I have proved them to be extremely effective!! (They still beat me, despite four whole hours of effort with a full array of power tools!!)
...... but then, that might just have proved nothing more than the fact that I wouldn't make a particularly good thief!!... I certainly won't be giving up the day job, to pursue a lucrative life of crime!! :lol: )
#7 jbs.998
jbs.998
  • 928 posts
Posted 03 December 2011 - 09:28 PM
Haha....;)
Come to think of it, wouldn't a are locking nut cap come in so bloody handy!
#8 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 03 December 2011 - 09:43 PM
A "spare"?? :unsure:
Yes good point, I will certainly be buying a replacement set that includes two removal tools, so that I have a spare next time (that is if you can buy such a thing?? :unsure: )
#9 jbs.998
jbs.998
  • 928 posts
Posted 03 December 2011 - 10:01 PM
Well if you can't it's defiantly something to go to dragons den with!
Il have £250,000 please for my great idea!!
Oh and you can have 10% of my spare lcking nut remover business!
#10 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,734 posts
  • Name: Adam
Posted 04 December 2011 - 01:32 AM
Can't you get a new key made up if you have the correct code?
#11 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 04 December 2011 - 08:37 AM
Mine didn't have any sort of code, I don't know if other locking wheel nuts/tools do???
#12 david@skeggyminis
david@skeggyminis
  • 352 posts
Posted 04 December 2011 - 08:52 AM
these are a good thing to have in the tool box http://www.ebay.co.u...=item35b4725de2
i have used mine for lots of jobs not just wheel nuts
#13 Nikral
Nikral
  • 274 posts
Posted 04 December 2011 - 09:14 AM
good idea but would 't work on mine as they have the rotating shroud over them.
#14 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 04 December 2011 - 09:16 AM
Thanks for the link, I don't think they would have worked in my case though as my locking wheel nuts were fitted with "rotating protector shrouds", which was part of the reason that I had such a problem trying to remove them (that and my complete lack of skill and ability obviously!!! :lol: )
#15 Carlos W
Carlos W
  • 10,114 posts
Posted 04 December 2011 - 11:19 AM
How tightly were they done up?
And how tightly are they meant to be done up?
I never torque up the locking wheel nuts on the mondeo (it does have 5 wheel nuts though)
