How tightly were they done up?
45 lb/ft
And how tightly are they meant to be done up?
Erm...... 45 lb/ft???..... or are locking wheel nuts supposed to be different??
Posted 04 December 2011 - 01:47 PM
Posted 04 December 2011 - 04:10 PM
Posted 04 December 2011 - 05:08 PM
Posted 04 December 2011 - 05:54 PM
You should definitely torque them up too!As I say, I never torque the mondeo locking nuts up, but its got 5 nuts per wheel!! Dunno what i'll do with the mini! It's a little way away from that stage!
Posted 04 December 2011 - 07:21 PM
Posted 04 December 2011 - 07:32 PM
The idea behind torqueing bolts/nuts is to have an even tightness all the way around.
You should also tighten them up in a sequence of going opposites and only tighten when all nuts are in place & nipped up!
Posted 04 December 2011 - 08:09 PM
Posted 04 December 2011 - 08:10 PM
Posted 04 December 2011 - 08:12 PM
I took my locking nuts off today and replaced then with standard wheels nuts, just not worth the hassle and the Mini is locked in the garage anyway.
Posted 04 December 2011 - 08:15 PM
Edited by Mini_Magic, 04 December 2011 - 08:16 PM.
Posted 04 December 2011 - 08:19 PM
Posted 04 December 2011 - 08:36 PM
Posted 04 December 2011 - 09:21 PM
Posted 04 December 2011 - 09:40 PM
mine seem to have good key on the way it fits on cant imagine it ever stripping.
Edited by AVV IT, 04 December 2011 - 09:41 PM.
Posted 04 December 2011 - 10:03 PM
Ouch Lee...... you like to tempt fate don't you??
No it never occurred to me for one minute that the pins would shear in my lock nut tool either. In actual fact when I felt something go crunch in my hand, I automatically assumed that I had sheared one of the wheel studs off and was quite surprised that it was actually the removal tool that was the problem.
I've often worried about loosing the lock nut removal tool, but it never actually occurred to me that it might break. I'm assuming that it was just because of fatigue, the lock nuts and the tool are pushing 20 years old now after all. My advice to anyone now would be that for the sake of a few quid, you could save yourself an awful lot of hassle by replacing your locking nuts and removal tool every few years or so. I was just lucky that mine broke during a spot of routine maintenance and therefore I was still able to drive the car somewhere in order to get it sorted. If however it had broke at the side of the road whilst I was trying to change a wheel, then things would have been much worse!! >_<
