Very Fast Road Spec 1098?
#46
Posted 11 January 2012 - 09:15 PM
I assume you time it up the same as you would a "normal" cam? I will be using the timing wheel jobbie and dti.
Cooperman did a great step-by-step write upof how to do it...need to find that thread... :-S
#47
Posted 11 January 2012 - 09:34 PM
#48
Posted 11 January 2012 - 09:38 PM
#49
Posted 11 January 2012 - 09:43 PM
#50
Posted 12 January 2012 - 09:35 AM
The 1098 crank is not weak when straped and balanced, no it will not like 8500 revs, but with a 286 it had plenty of torque.
#51
Posted 12 January 2012 - 07:08 PM
Edited by callyspoy, 12 January 2012 - 07:09 PM.
#52
Posted 12 January 2012 - 07:14 PM
Edited by bmcecosse, 12 January 2012 - 07:14 PM.
#53
Posted 04 February 2012 - 02:49 PM
Just wondering if i am missing anything? Any tricks before i take the engine back out and rebuild the bottom end?
As a recap it is...
1098 bored out to 1215
940 head
286 cam
I assume any rumbliness is pretty much a no go?
Any help, moralsupport appreciated!!
#54
Posted 04 February 2012 - 03:29 PM
#55
Posted 04 February 2012 - 03:45 PM
The sensible thing to have done would have been to dismantle it, i didn't, that's life regarding that.
Just wondered if there is anything i can do? I feel it is inevitable that it'll be coming back out again, but just wondered if there was any magical thing that may help. I do like magic.
#56
Posted 04 February 2012 - 10:03 PM
#57
Posted 04 February 2012 - 11:02 PM
#58
Posted 05 February 2012 - 12:14 AM
so the person that wanted advise actually got good advise and chose to totally ignore it, so what was the point of this thread in the first place??
and now the engines bottom end is knocking and there is no oil pressure...........i say no more........!!!
#59
Posted 05 February 2012 - 12:28 AM
To be blunt, it's fairly useless having a cam which peaks at around 6500 rpm in a 1098 if can't rev it safely beyond 6000 rpm because you are gaining nothing and losing a lot low down where a 1098 is at its best. The 286 is entirely unsuitable for a 1098. The hottest cam I've ever put into a 1098 was a 276 in a Historic motor sport A-H Sprite Mk.1. That was with a fully balanced bottom end, centre-main bearing strap, light flywheel, big crank damper and lightened rods. even then I told the owner not to use more than 6300 rpm, but the 276 is fine with that limit, unlike the 286 which really needs to be able to rev to 6700 to 6800 to be effective.
It is also unwise to try to get more power from an engine without rebuilding the bottom end and to risk running an un-rebuilt 1098 to over 6500 is asking for a gearbox full of engine parts and the subsequent need for a new engine and gearbox.
#60
Posted 05 February 2012 - 12:38 AM
The comments made by 'bmc...' are quite correct.
my sentiments and thoughts exactly, i'm no expert on engines but even i wouldent run that spec on a 1098, that is just asking for trouble (and a lot of unwanted expense)
