Bit of a thread resurrection, but I'm having this problem, except the bolt is still in place, but the thread has stripped (bits of thread on the bolt). Not sure how I overtightened it, since it was only a short ratchet, but hey ho.
Is there anything wrong with just re-tapping the thread?
Radius Arm Bracket Bolt Spinning
Notay
, Dec 09 2011 11:36 AM
23 replies to this topic
#16
Posted 05 July 2012 - 08:47 PM
#17
Posted 06 July 2012 - 12:03 PM
Anyone?
#18
Posted 06 July 2012 - 05:17 PM
Can someone please answer? My cars been up on axle stands for a month.
#19
Posted 06 July 2012 - 05:18 PM
You'll have to tap it oversize as there's nothing left to tap a thread into.
#20
Posted 06 July 2012 - 08:28 PM
Will it be stable enough, what with people saying their captive nuts had come free?
#21
Posted 08 July 2012 - 07:13 PM
Ok. I've come to the conclusion that I simply don't have the tools to cut the old captive nut out of such a small space, never mind weld a new one on.
If I file the thread out of the stripped nut, and use a longer bolt, can I just screw a new nut onto the other side with a bit of loctite?
#22
Posted 08 July 2012 - 08:44 PM
Hellloooooooo!?
#23
Posted 09 July 2012 - 11:49 AM
Any response? Getting withdrawal symptoms. Must have Mini!
#24
Posted 09 July 2012 - 07:29 PM
Never mind.
In the end I drilled the old thread out and fastened the bolt with a nyloc nut. What an absolute pain in the bum it was! Getting the nut located above the trunnion pin was an utter pig of a job. Its holding absolutely solid, but I'd recommend anyone else who encounters this problem to cut the subframe and weld a new captive nut in.
It really isn't worth the nervous breakdown I nearly suffered.
Either way, it's done. Next time, I'm spending £450 on a new, built up subframe.
