Why Don't They Make Stainless Panels?
Posted 29 December 2011 - 01:43 PM
Any thoughts? I know it'd be a fair bit more expensive to do so.
Posted 29 December 2011 - 01:46 PM
No rust, and light weight.
Posted 29 December 2011 - 01:50 PM
If you replace you front end, protect and care for it correctly it should last a good 8 years.
Posted 29 December 2011 - 02:01 PM
Posted 29 December 2011 - 02:11 PM
So simply put, they don't because they cant.
Posted 29 December 2011 - 02:48 PM
I do know of a mini van that has a full 2.5mm thick galv floor in it.
Posted 29 December 2011 - 03:08 PM
Edited by AVV IT, 29 December 2011 - 03:09 PM.
Posted 29 December 2011 - 03:22 PM
My mini is 22 and I just removed its original front end. Wasn't horrendous but quite scabby. Hopefully my new front will last longer than 8 years before needing replacement. Especially with Wing liners fitted. Stone chipped, seam sealed and waxoyled
my mini is now 21 years old and still has the original front end and won't need replacing soon
i asked this question about this time last year and the ones that know pointed out there would be electrolis between the 2 different metals causing corusion
Posted 29 December 2011 - 03:25 PM
Surely aluminium would be better?
Correct me if I'm wrong, but can't you buy aluminium door skins already ??
Posted 29 December 2011 - 03:27 PM
Posted 29 December 2011 - 04:26 PM
aluminium also does corrode, badly! I have an X350 jag which is fully aluminium and they have corrosion issues because jag, in their wiseness, used stainless steel rivets. Not a problem until water gets under the paint and then electrolisis occurs at an alarming rate so even on a 6 year old new aluminium car you have to watch out for stone chips and other tell tale signs
I didnt know that, thanks.
Posted 29 December 2011 - 06:15 PM
Posted 29 December 2011 - 06:19 PM
Posted 29 December 2011 - 06:54 PM
