Why Don't They Make Stainless Panels?
81 replies to this topic
#16 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 29 December 2011 - 07:44 PM
Opps, I made a battery box out of some stainless flashing i got from work and plug welded it to my boot floor. Hope i haven't created more problems for myself. I did think about bonding it to the floor, maybe i should've done that instead!
#17 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 29 December 2011 - 07:46 PM
i bonded the stainless battery trays into my camper
#18 Brams96
Brams96
  • 2,308 posts
I was going to make an aluminium battery box & pop-rivet it in with some bonding as well, not sure that's a good idea now? :unsure:
#19 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 29 December 2011 - 07:50 PM
bond but don't rivet,it's not like it's going to fall out
#20 Carlos W
Carlos W
  • 10,114 posts
Posted 29 December 2011 - 07:51 PM
Dunno, you may need an SVA, it's part of the monocoque!
#21 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 29 December 2011 - 07:52 PM
There is no reason why panels should not last for decades, other than poor quality materials and inadequate protection... I have 3 minis in my unit which all have their original panels, and not one newer than 1980.
#22 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 29 December 2011 - 07:54 PM
did cross my mind but as it's away from the subframe mounts and bulkhead you might get away with it
#23 Carlos W
Carlos W
  • 10,114 posts
Posted 29 December 2011 - 07:55 PM
It's not that far from the subframe mount, the rear offside one is less than 15cm away at a guess!
Edited by Carlos W, 29 December 2011 - 07:56 PM.
#24 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 29 December 2011 - 07:58 PM
Thanks all, plenty of good reasons why not then!
True, certainly would be within the MOT fair area if it were excessively corroded. However, it can't exactly be structural as there's no way any loads could be put though it.
#25 Carlos W
Carlos W
  • 10,114 posts
Posted 29 December 2011 - 08:01 PM
Sorry Luke, I was taking the piss
Edited by Carlos W, 29 December 2011 - 08:01 PM.
#26 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 29 December 2011 - 08:04 PM
but like guessworks said it's not a area that rusts fast, there is no rust at all around the battery tray of my 21 year old mini
#27 Carlos W
Carlos W
  • 10,114 posts
Posted 29 December 2011 - 08:05 PM
There's a bit of corrosion in mine caused by battery acid!
#28 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 29 December 2011 - 09:07 PM
Aluminium Oxidises which is just a posh word for aluminium rust, dont think it actually corrodes through to make holes though ? just makes the paint flake off..
#29 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 29 December 2011 - 09:10 PM
When alu oxidises it forms a white skin that's fairly tough, in theory stopping it oxidising further. I should stress the in theory bit.
#30 miniman24
miniman24
  • 1,696 posts
Posted 29 December 2011 - 10:41 PM
Before my Mum reversed into my Mini it had its original 20 year old front end on, the drivers wing was fillered around the scuttle but other than that it was pretty much spot on! Now has a fibreglass front so I dont have to worry about rust anyway :lol:
