I'm Gonna Cry In A Minute
60 replies to this topic
#1 conlad
conlad
    Previously known as ct16mini.
  • 2,054 posts
  • Local Club: Hilltop Minis
Posted 30 December 2011 - 09:50 AM
Cant get the bloody fuel pump off!!
Its a 998 mech pump.
I've took the carb and throttle body etc all off and still cant get the rachet in there. Spanners are a no go too. Too many things are in the way in the engine!!
Anyone have a neat trick to get it out easier?
If its this hard just getting the old one off I cant wait for the new one :-|
Cheers TMF'ers
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 30 December 2011 - 09:56 AM
Have you removed the engine steadies so you can pull the engine foreward to give more access. ??
I used a ring spanner was a pain but got there
#3 conlad
conlad
  • 2,054 posts
Posted 30 December 2011 - 09:58 AM
Nope, but is this easy?
Would you jack it up?
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 30 December 2011 - 10:08 AM
Engine steadies are easy enough only 2 bolts either end. Normally one top left of engine, and one bottom left.
Then you'll need a length of wood to prop between bulkhead and engine so you can wedge it foreward whilst you work on the pump.
#5 conlad
conlad
  • 2,054 posts
Posted 30 December 2011 - 10:09 AM
Daft question but once the steadies are out, the engine wont fall around will it?
#6 classic clubman
classic clubman
    Starting My Mini Up
  • 1 posts
Posted 30 December 2011 - 10:16 AM
not if your engine mounts are good
#7 conlad
conlad
  • 2,054 posts
Posted 30 December 2011 - 10:19 AM
Hokey kokey, cheers lads ;D
#8 ChrisG10
ChrisG10
  • 308 posts
Posted 30 December 2011 - 10:41 AM
I can get to mine by just removing the top engine mount but i do have some very nice ring spanners which seem to be the perfect angle!
#9 MrBounce
MrBounce
  • 2,661 posts
Posted 30 December 2011 - 11:16 AM
1/4" drive ratchet should fit nicely in there. Never had a problem getting to mine although I do have small hands...
#10 sledgehammer
sledgehammer
  • 3,108 posts
Posted 30 December 2011 - 11:46 AM
massive advantage on a mini
also if your older (or have arthritis like me) , soak hands in hot water , and a quick exercise , makes them more flexible ;o)
#11 conlad
conlad
  • 2,054 posts
Which mount/bolt would that be? You lucky bugga haha!
Got my 1/4 drive in there but no room to move it round! Another lucky bugga lmao ahhhhh dunno what to do now, I simply cannot undo the bolt
#12 MrBounce
MrBounce
  • 2,661 posts
Posted 30 December 2011 - 02:48 PM
Ratchet spanner?
#13 conlad
conlad
  • 2,054 posts
Posted 30 December 2011 - 03:08 PM
Ratchet spanner?
Hmm, they are way too expensive to be honest. As nice as they are they just wont get used.
ChrisG10 said somethign about the engine mounts, what would you undo to gain better access? I un-did the engine steadies but that only got me like 1-2cm extra which is nothing to be honest. Any help would be greatly appreciated cheers!
Edited by ct16mini, 30 December 2011 - 03:09 PM.
#14 jaydee
jaydee
  • 8,565 posts
Posted 30 December 2011 - 04:01 PM
By removing engine steadys yes you gain no more than 2 cm, anymore means your engine mounts are shot..
You need patience and the appropriate ratchet..
#15 Beej123
Beej123
  • 1,184 posts
  • Local Club: Splinters Mini Club
Posted 30 December 2011 - 04:07 PM
Just undo the mounts too, sometimes a bit tricky to get back on but you can move the engine loads
