Gearbox Box/diff Blown
Posted 01 January 2012 - 03:13 PM
Posted 01 January 2012 - 04:45 PM
Posted 01 January 2012 - 04:49 PM
Why do you think you've blown the diff?
Posted 01 January 2012 - 07:22 PM
just was to know if i can just change the diff without changing the box or should i just change the whole thing
Posted 01 January 2012 - 07:24 PM
Has it got an LSD?
If not, could you have broken a drive shaft or something?
Posted 01 January 2012 - 07:41 PM
Posted 01 January 2012 - 07:43 PM
Posted 01 January 2012 - 07:45 PM
Posted 01 January 2012 - 07:48 PM
Posted 01 January 2012 - 07:49 PM
Posted 01 January 2012 - 07:52 PM
A rally Mini does need a cross-pin diff if it's putting out any serious power on un-surfaced and/or bumpy roads.
Don't take any chances, strip & check.
I strip & check my engine & gearbox after every 6 or 7 rallies even if there is no obvious problem. Mini transmissions are the main cause of retirements from ralliues - I've done many over the years.
Posted 01 January 2012 - 07:59 PM
ill have a look at the drive shafts 1st but will remove the engine and most prob put a lsd in it
Posted 01 January 2012 - 08:12 PM
As above check the CV joint splines before stripping everything down. When you said you had blown the diff I assumed you had already eliminated the CV joints as a cause of the loss of drive.
Posted 01 January 2012 - 08:17 PM
Posted 01 January 2012 - 08:18 PM
