Did the steering go strange just before the breakage?
yes
Posted 01 January 2012 - 08:50 PM
Posted 01 January 2012 - 09:58 PM
Posted 01 January 2012 - 10:08 PM
Posted 01 January 2012 - 10:16 PM
Posted 01 January 2012 - 10:20 PM
Posted 01 January 2012 - 10:28 PM
The trick is not to have the diff set too tight..... and of course - throw the car at the corner and power through with the wheels straight ahead! Easier said than done of course..... I loved the welded diff in my Autocross car......
Posted 01 January 2012 - 10:36 PM
Posted 01 January 2012 - 10:37 PM
thanks for the info ill check it out tomorrow
Posted 02 January 2012 - 12:53 PM
Posted 02 January 2012 - 01:07 PM
Posted 02 January 2012 - 02:49 PM
Posted 02 January 2012 - 04:17 PM
Posted 02 January 2012 - 05:49 PM
Posted 02 January 2012 - 06:29 PM
Posted 02 January 2012 - 06:41 PM
If a CV joint is broken when that side wheel is jacked up the wheel will rotate and the shaft will stay still.
When the other side is jacked up and the wheel rotated both shafts will rotate.
It does sound like a drive shaft/CV problem rather than a diff issue.
