Mega Jolt
35 replies to this topic
#16 charliedurrant
charliedurrant
  • 519 posts
  • Local Club: There isn't one down my way
Posted 02 January 2012 - 01:06 AM
Just to clear up when you go to the scrappies locate the associated wireing. On a fiesta you can remove the edis plug and the whole length of vr sensor wire and plug also coil pack wire and plug complete. So there's no need to worry about them. You will however need to. Cut the pip & saw wires and the +12v & ground wires to be able to remove the edis plug.
Yes, good point, that is an advantage and something I didn't think about - it's all wired up already! So therefore it's just 4 wires to the megajolt plug as you said. Take up he offer Callum otherwise someone else will!
#17 bunch1980
bunch1980
  • 1,192 posts
  • Local Club: nein
Posted 02 January 2012 - 11:03 AM
As far as I know and if you look at pics in thread where wilson has loom for sell it comes with all the plugs to so is plug an play. Yeah I knew if I myself was cutting it from a donor vehicle I could use wiring then but I am not able to do that now and already have 2 edis4 and 2 coil packs so if any are faulty can use one or other.
For me its going to be peace of mind to know wiring is correct and tested with out damaging other parts.
I am also getting the brackets from wilson for edis and coil as I dont really have to the tools to make my own at home at the mo. Or access to any tools to do so.
Maybe if its so easy I_jonez could start banging out looms for us if we supply the wires? lol but as been discussed in last few posts above there is more to it that meets they unless you have done it before or sourced from a donar car.
Edited by bunch1980, 02 January 2012 - 11:16 AM.
#18 cng1
cng1
  • 10 posts
Posted 02 January 2012 - 12:52 PM
Note: I don't like commercial posts and try to avoid them wherever possible but since there is a lot of discussion of our (Trigger-wheels.com) products going on that I thought that it was worth a response from the horses mouth.
The wire isn't so much the issue as the connectors. Go to a breakers and used coil packs are easy to come by, EDIS modules not too hard either but getting ever harder. Go to ebay and you'll find a number of them but in general they won't come with connectors. EDIS module connectors on their own are pretty much impossible to find.
It took us a couple of years to secure a reliable source of coilpack connectors and pins and it's only in the last few months that we've been able to do the same for EDIS-4 connectors. Sadly the convoluted route we have to use to source the EDIS-4 connectors means they're not cheap. The new coilpack connectors though we buy in _huge_ quantities so thankfully work out much more reasonably priced and because of the better availability of parts we're able to supply used connectors for people pinching every last penny. Because we purchase so many of those coilpack connectors that has improves access to the parts for lots of other businesses which have been able to do stuff on the back of what we have done, whilst some of their offerings compete with our own the overall benefit to the "ecosystem" is positive which is fine by us.
From what I have seen if Wilson is able to do the coil/crank sensor/EDIS part of the loom using parts you supply for £45 inc vat then that seems like a pretty fair price to me. I do have some concerns over the crank sensor brackets that he is selling though - it might be that the pictures I have seen are misleading me but having done thousands of the things over the years I'm happy to offer the Wilson the benefit of our experience developing/testing/producing/supporting such things offline. Likewise we're always looking for good dealers/fitting agents etc so if Wilson would like to get in touch with us there may be a useful conversation to be had there in that respect.
I personally don't really understand people sourcing their ECU from the states. Sure on paper it might work out 10-15% cheaper than than buying the ECU alone from us (As an aside yes you can do that, people don't seem to realise it but we can supply the bare ECU or the complete A-series package or anything in between) but it only works out that cheap if you don't get a customs charge.. In theory anything bought from outside the EU worth over £15 in value is subject to VAT (and potentialy import duty as well). Yes a proportion of consignments escape the charges but if you're not one of the lucky ones you get charged 20% VAT, an £8 "collection fee" plus any applicable import duty on top of all that. All of a sudden your 10-15% cost saving has turned into a pretty bad deal. What's more because you've purchased from the states any warranty is with them - you've lost out on the benefit of having local support (which if you ask any of our customers I suspect they'll rave about). Whilst we'll probably still offer some support if you purchased your system from someone else because we're nice people there are limits to how much we can do and our paying customers have to come first.
I know that Charlie had some issues mounting his coil pack using our standard bracket in his desired location. For whatever reason this wasn't an issue that we'd come across before on all the many hundreds of installs but as a result we're going to be producing some new backets that will give improved flexibility. We also now stock an alternative "bulkhead" mounting bracket, which whilst not mini-specific might be of use. If Charlie wants to try out either of these options he is welcome to get in touch and we can let him have one to try out and give his stamp of approval to.
#19 l_jonez
l_jonez
  • 1,453 posts
Posted 02 January 2012 - 02:01 PM
It's certainly possible, if people supply me with the plugs with a few inches of wire or from a fiesta with the vr sensor and coil leads as mentioned
#20 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 02 January 2012 - 05:59 PM
I take it that cng1 is in fact Chris at Trigger Wheels.I would just say the following:- I am one of those paying customers and am very glad I chose to be. Chris' after sales help has been 2nd to none and he has helped no end when ever I have had cause to shout for help.He has remained patient and professional even though I have probably tried that patience,so much so I will hide behind my user name in case he realises it's me!! I did as he mentions and purchased the ecu only(and tacho driver),he doesnt take offence if you want to crawl round old Fords and get the other bits as I did. So,go to America if you like but this is a vote of confidence for Trigger Wheels :thumbsup:
Edited by Pigeonto, 02 January 2012 - 06:00 PM.
#21 l_jonez
l_jonez
  • 1,453 posts
Posted 02 January 2012 - 06:10 PM
I also used trigger wheels but it was back in 2004-2005 ish and they only did the universal wheel at the time. I've recommend them a fair few times and from what I've seen they are very good.
#22 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 02 January 2012 - 07:08 PM
Would just like to add that we discuss all our packages and tailor them to each persons requirements. Our loom for £45 includes the coil pack connector and the VR sensor plug, which alone come to around £15 to buy retail, we also maintain the colour scheme of the ford EDIS system making it far easier to trace the wires should you need to. For £45 we would be making a huge loss to supply the EDIS plug also.
We do not supply the pins nor the molex plug as if we did you would then struggle to get the plug through the bulkhead. If needed we can fit the pins so you only have to push them into the plug. We do however supply very clear and straight forward installation instructions
As Chris has said the EDIS plugs are becoming incredibly difficult to find, hence why we offer a cheaper package if people supply there plugs.
So in our final defence l_jonez, it would be very easy to make the loom for half the price if you are supplied with all the wires and the plugs!!!
To be honest im getting tired people on this forum bashing those with initiative and those trying to be helpful. That is all myself and a friend are trying to do by making these looms with little profit in them. Our main business is doing small volumes of powdercoating at cheap prices.
Chris, I will send you a pm.
If anyone has an issue with our product then feel free to contact me directly rather than tarnish my name on a public forum.
David
Edited by Wilson1330, 02 January 2012 - 07:22 PM.
#23 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 02 January 2012 - 07:21 PM
Our completed loom.
#24 cng1
cng1
  • 10 posts
Posted 02 January 2012 - 08:18 PM
Yes, you are quite right. I don't put that in my forum signature as I personally disapprove of such surreptitious advertising but I'm not going to hide who I am! :)
Thanks for your kind words. We like to think the service we offer is excellent but it is always nice to hear that our customers think so too. We're always surprised when a customer asks a question of us like "Do I get support?", "Is there a warranty?" as to us it seems incredible that anyone could think that they wouldn't get the 100% support of their supplier. I guess that people feel the need to ask is a sad reflection of how some other companies in the industry do business. Likewise we have to smile when someone asks how difficult it is to solder up one of our ECUs, not realising that what they get is not a kit of parts to build an ECU but a complete, tested and guaranteed system with all the support from us that goes with it.
#25 cng1
cng1
  • 10 posts
Posted 02 January 2012 - 08:44 PM
Including a new crank sensor plug and coilpack plug in at £45 then that really is super value, by the sounds of it we should definitely talk. Just out of interest are you using the cheaper microphone cable for the shielded connection on the crank sensor that I know some people use or the Mil-spec stuff that we recommend? Thinking about it rather than clutter up the forum with the two of us sad folk discussing the minutia of megajolt installations feel free to mail us privately ([email protected]).
I think you'd be ok actually as long as you have enough free cable before the start of the strain relief in order to be able to bend the wires along the length of the connector. In any case the customer will have the molex connector with the ECU so no sense you supply an extra one so I think your current approach is probably correct.
Gosh yes. Half hour job even allowing for a quick mid-job tea break. When we make a loom from scratch we spend roughly half a day on it and use something like £60 (our cost price when we buy in bulk) of materials. Given that typical workshop rates in the real world are £40-80 per hour it's pretty easy to see that making a loom isn't a cheap job. We like to think that the looms we make ourselves are rather nice but I can very much understand why some people think they are expensive. Hence one of the reasons why by default we supply people with the necessary materials and instructions to be able to do the job themselves (or get a mate to do it for a few beers). If people don't want those parts because they're getting a loom from someone like you, already have the parts or even if they want us to build them a custom loom it is all fine by us.
Super, sounds like we have lots to talk about.
Chris
#26 l_jonez
l_jonez
  • 1,453 posts
Posted 02 January 2012 - 08:50 PM
I have no problem with your product and nor have I slated it. what I said was you would be stupid to pay for a loom when you can get it off the fiesta etc and it be pretty much done just add in a required length of shielded cable.
The offer of half price was to coopdog because I know him.
#27 l_jonez
l_jonez
  • 1,453 posts
Posted 02 January 2012 - 09:01 PM
Heres what a you can expect if you remove it from a fiesta
Little bit of a tidy up add the shielded cable and away you go
Edited by l_jonez, 02 January 2012 - 09:04 PM.
#28 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 02 January 2012 - 09:37 PM
Apologises l_jonez.
Our loom is designed to fit around the outside of a mini engine bay and basically custom fit it. I infact made my own loom from a fiesta donor but having a complete loom with no soldered joins would have been a must for me should I have known what i know now.
Our looms are complete sections of wire form end to end - i.e. no cut and shut wires with solder and heatshrink.
Chris, we are keen to chat to you :)
#29 charliedurrant
charliedurrant
  • 519 posts
cng,
Firstly, it's excellent that you posted on here and in no way a commercial hike, and I hope I have not caused any offence - genuinely that's not my thing.
Some points:
1) I was a little put out by the description in the kit that it contained a 'loom kit'. The reasoning for separate wires and providing long lengths makes sense that it makes the installation flexible. But, I would not describe it using the word 'loom' as I think that word conjours up ideas - well I did in my head. If nobody else has mentioned it then I was reading too much into it.
2) As to the bracket, I was expecting it to mount on the bell housing (it seems to be common place to mount it) but it didn't have any holes to mount as such. It's a general mount and again not mini specific. My drilling skills are poor and getting holes 66mm apart to mount on the bell housing was not so easy for me (I am very slow at all this). The circular cut out holes make it so you can only mount the coil pack one way, with more weight distributed to the left and right. I would have thought it was more logical to fit the mount with the major portion of the weight along the bell housing. This is again particularly mini specific as is mounting on the bell housing, I am just copying what I have seen as ideally I'd prefer to mount at the 4 corners of the bracket.
3) As to the EDIS, I've become a little disconnected from cars over the years and since I drop my wife off by a scappy which has 4 fiestas in view from the road, I wished I gone and been a little more gung ho and got the parts from there.
It's a very kind offer for the alternative bulkhead mounting bracket. It wont go on my Mk II as my water bottle is in the way. Also, I've already drilled the 'holed' bracket and it would not be right to swap it over - it does its job!
The bulkhead bracket could be worth having as an option for other MKs which don't have the water bottle restricting fitting. Having electrics away from the grille area can only be a good thing!
Charlie
Edited by charliedurrant, 02 January 2012 - 09:49 PM.
#30 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
Posted 04 January 2012 - 10:27 AM
Seems we have started quite a debate!!
